I have no audio on lubuntu 12.04 after resuming from suspend. I tried
sudo alsa force-reload
to no avail. Sound works after reboot. Please help.
Eric Carvalho
  • 55,453
akonsu
  • 601
5 Answers5
For some systems it is necessary to kill the pulseaudio process and prevent it from re-loading before restarting ALSA. If the following procedure works, it can be automated.
  1. Set up Pulseaudio so it does not respawn automatically:
    mkdir ~/.pulse
    echo "autospawn = no" >> ~/.pulse/client.conf
  2. Suspend your computer and wake him up
  3. Restart ALSA:
  4. Start pulseaudio:
    pulseaudio --start
To revert the changes, delete the file ~/.pulse/client.conf
zerwas
  • 3,943
After consulting some posts, what I've done to get mine to work again:
  1. Set pulseaudio not to respawn by creating config file at home directory:
    mkdir ~/.pulse
  2. Create a file (50alsa) to automate after system suspend.
    sudo gedit /etc/pm/sleep.d/50alsa
  3. Add the following to the file. Notice 'pulseaudio --kill' added.
    case "$1" in
            hibernate|suspend)
                    # Stopping is not required
            thaw|resume)
                    pulseaudio --kill
                    /sbin/alsa force-reload
                    pulseaudio --start
            *) exit $NA
    esac
Boyi
  • 39
Try pressing CTRL+ALT+F1 to change tty screens then press CTRL+ALT+F7 to go back to desktop.
This sometimes brings back sound but failing that, change screen resolution and change it back for a different fix. This works for HDMI audio as well.
Peachy
  • 7,235
  • 40
  • 47
I tried this, but that didn't help.
To solve this without restart or another suspend, I solved it with simply
pulseaudio --kill
pulseaudio --start
rubo77
  • 34,024
  • 52
  • 172
  • 299
Try running
pulseaudio -k && sudo alsa force-reload
842Mono
  • 10,070
