I found out that listening to radio in terminal using "mplayer url" is much better than any software around, but after a while, terminal prints out a message saying low on cache.
How can I increase the cache in the terminal? Is it possible to free the used cache periodically while listening to the radio?
Jorge Castro
  • 73,717
user90939
  • 175
You can set mplayer's cache with -cache argument on command line as well as specifying the initial cache fill before playback with '-cache-min'.
Try:
$ mplayer -cache 8192 -cache-min 80 <url>
p.s. 8192 should be enough, however, you can increase that number according to your needs. Note that the initial cache fill without the '-cache-min' option is only 20%.
andrew.46
  • 39,359
To listen Internet-Radio from a terminal I would recommend pyradio
As far as I know it uses mplayer and vlc in the background but has a really nice command-line interface.
makim
  • 727
