Possible Duplicate:
How can I repair grub? (How to get Ubuntu back after installing Windows?)
My system was configured to dual boot Ubuntu 12.04.1 LTS and Windows 7. Today I got my hands on the MSDN release of Windows 8 and I installed it over my Windows 7. Now the computer just boots to Windows 8 directly without loading the GRUB screen.
So I followed the steps as suggested in: https://help.ubuntu.com/community/RecoveringUbuntuAfterInstallingWindows. Running this command:
ls -l /dev/disk/by-label/
gives the following output:
total 0
lrwxrwxrwx 1 root root 10 Sep 11 07:51 Entertainment -> ../../sda2
lrwxrwxrwx 1 root root 10 Sep 11 02:45 PENDRIVE -> ../../sdb1
Also fdisk -l command gives this as the output:
Disk /dev/sda: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders, total 625142448 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x1246aa23
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 319582199 159790076 7 HPFS/NTFS/exFAT
/dev/sda2 319582208 602906623 141662208 7 HPFS/NTFS/exFAT
/dev/sda3 602908672 625135615 11113472 83 Linux
Disk /dev/sdb: 1939 MB, 1939865600 bytes
64 heads, 63 sectors/track, 939 cylinders, total 3788800 sectors
Disk identifier: 0xc3072e18
/dev/sdb1 * 2248 3788799 1893276 c W95 FAT32 (LBA)
So I assume that I have to run this: sudo grub-install /dev/sda3 to get GRUB up and running. But I am getting this error:
/usr/sbin/grub-probe: error: cannot find a device for /boot/grub (is /dev mounted?).
Can anyone please guide me in the right direction? The current Ubuntu installation is far too customized to my needs to lose it to a boot manager issue! Any help is much appreciated!
