I installed Zorin 6 (based on Ubuntu 12.04), because I like all the whistles it has (plymouth screen,compiz effects,installed codecs, sound themes, etc.). I miss though the modern and futuristic unity environment (launcher, dash, HUD, indicators etc.).
  1. Is there a way to switch from Zorin to Ubuntu 12.04.1 LTS and keep all these effects? Or
  2. What additional software should I install in an Ubuntu clean install to add the effects Zorin has (plymouth, compiz effects, sounds, audio and video codecs etc.)
Anwar
  • 77,855
SteliosSk
  • 331
I suggest you to install Ubuntu on another partition.
Then install the software included in Zorin in Ubuntu. You can install these
  1. Compiz config settings manager with sudo apt-get install compizconfig-settings-manager.
  2. All necessary codecs, MS fonts and flash by using sudo apt-get install ubuntu-restricted-extras
  3. Install Ubuntu-tweak : How do I install Ubuntu-Tweak?
After installing necessary software, copy the configuration folders from the old Zorin partiton to your Ubuntu home. The folders are .config, .gconf and .compiz-1 and if you want .local (this may not be needed).
Anwar
  • 77,855
I don't think you can just revert to Ubuntu.
However, you can install additional software in Ubuntu which can make your experience somewhat the same.
  • plymouth is already installed in Ubuntu 12.04.
  • Compiz effects can be achieved by installing compizconfig-settings-manager.
  • Audio and video codecs can be installed by installing ubuntu-restricted-extras.
green
  • 14,406
