I certainly like notifications in 12.04, but depending on the work I do they can be quite distracting.
Is there an official way or a tweak to temporarily deactivate notifications?
UPDATE: To clearify, I am looking for a way to do that in Unity.
This is how I achieved it
Create a sh file called stopNotification.sh and paste this line
killall -s SIGSTOP notify-osd
Create another sh file and continueNotification.sh and paste following line
killall -s SIGCONT notify-osd
Then goto system settings > keyboard and assign a shortcut for it.
Simple :)
I don't believe there's an official way, but it's easy enough to disable in the terminal (for presentations, etc.):
sudo chmod 000 /usr/lib/notify-osd/notify-osd
killall notify-osd
Afterward, just chmod it back to 755 and notifications will resume.
Relevant: http://brainstorm.ubuntu.com/idea/25512/
Use NoNotification and use don't disturb mode :)
https://launchpad.net/nonotifs
You can save lost notifications to check them later.
sudo add-apt-repository ppa:vlijm/nonotifs
sudo apt-get update
sudo apt-get install nonotifs
You can disable popup notifications (the bubbles) graphically.
Open System Monitor, find the process named notify-osd, right click on it and select stop; if you want notifications back, right click again on the process and click continue.
Notes.
notify-osd, otherwise they remain locked there.notify-osd is disabled, shortcuts doesn't work well; I mean, all shortcuts (even Ctrl+Alt+L for example). This doesn't always happen and is particularly evident when you use keyboard shortcuts for audio (e.g. to mute, increase or decrease volume, but also to pause or change the music).Do the following
simply disable process notify-osd from system monitor
Stop Process : To stop popping up notifications
Continue Process : To continue popping up notifications
