I have Dell vostro 3500 Laptop. I Installed Ubuntu 12.04. It doesn't detect my bluetooth. below is my information.
lsusb | grep Bluetooth
Bus 001 Device 003: ID 0a5c:4500 Broadcom Corp. BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth)
lsmod | grep bluetooth
bluetooth             158438  10 bnep,rfcomm
rfkill list
0: brcmwl-0: Wireless LAN
Soft blocked: yes
Hard blocked: no
1: dell-wifi: Wireless LAN
Soft blocked: yes
Hard blocked: no
(wifi working fine. I disabled it using network menu. So, it's fine)
dmesg | grep Bluetooth
[   21.981835] Bluetooth: Core ver 2.16
[   21.981872] Bluetooth: HCI device and connection manager initialized
[   21.981877] Bluetooth: HCI socket layer initialized
[   21.981881] Bluetooth: L2CAP socket layer initialized
[   21.981891] Bluetooth: SCO socket layer initialized
[   21.986047] Bluetooth: RFCOMM TTY layer initialized
[   21.986059] Bluetooth: RFCOMM socket layer initialized
[   21.986065] Bluetooth: RFCOMM ver 1.11
[   22.361783] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   22.361791] Bluetooth: BNEP filters: protocol multicast
So How can I fix this?
I saw other place (I don't remember which site) They said, some times, when in windows, if bluetooth disabled by windows driver, It can't be enabled by linux. So, I should install windows and enable blueethooth from windows and then re install linux. That is impossible for me, because I don't have Windows installation media.
But I tried this, which is I installed windows xp on virtual box. Vbox showed me thow unknow USB devices. I connected them and installed windows bluethooth drivers to xp. But it didn't ditected Bluethooth either. Also, when I set off mode in hardware switch, those unknown devices disappear from Vbox usb device seletcion menu. So, they are definitely something to do with wifi or bluethooth.
Please help me..
Glutanimate
  • 21,763
vishwaje
  • 129
First, make sure it is not blocked as shown in the answer of rmaultz, i.e. make sure you turn on the bluetooth from the radio switch and bluetooth applet. Then run this
modprobe btusb
then run
lsmod | grep btusb
to confirm btusb module is loaded. Then run
lsusb
You should get something like
Bus 003 Device 005: ID 0a5c:4500 Broadcom Corp. BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth)
Then run this
sudo sh -c "echo 0xY 0xZ > /sys/bus/usb/drivers/btusb/new_id"
replace Y and Z from lsusb result for example
sudo sh -c "echo 0x0a5c 0x4500 > /sys/bus/usb/drivers/btusb/new_id"
Let me know, if that worked.
Zeiss
  • 101
rfkill list
Soft blocked: yes < --- Software  is Blocking the  blue tooth from being  Enabled
Hard blocked: no
Hard blocked: no
To keep unblock after rebooting add the option to the following file from terminal type sudo gedit /etc/rc.local
add rfkill unblock all
Proofread, save and close Gedit. Enjoy!
Peachy
  • 7,235
  • 40
  • 47
rmaultz
