How can I auto-mount all my hard disk partitions?
- Install pysdm
- After installation it will be found under System > Administration > Storage Device Manager
- Select your partition from the partition list and click Mount and then Apply.
- Also for more information you can check this post.
- 72,312
- 84,513
Search for "disks" from dash home. After you click the application called Disks, you should get a window something similar to this.
Click the Partition you would want and click the gear icon you see below it. Click Edit mount options. You will be presented with a window. Enable the automatic mount options by just sliding it to ON. Do this for all the partitions you want. And you are done! After next reboot, all the selected partitions will be mounted automatically.
- 72,312
/etc/fstab is a configuration file that contains information of all the partitions and storage devices in your computer.
Make an entry there as below:
/dev/hdb1 /home ext2 defaults 0 0
etc ... just change partition names , mount points , Fstype.
Your partition will be mounted on next boot.
- 14,522
Download a utility called pysdm. When installed it should show up as Storage Device Manager under System > Administration. You can then set the drive to automatically mount from there.
What it actually does is alter a file on your system called fstab, which tells your system what filesystems to expect, but it's much easier to use the utility to edit it rather than doing it manually.
- 72,312
- 1,209
Automatic mounting could also done using udisks a command line tool. This is the modern replacement for gnome-mount. It's not gnome specific.
When you mount a disc normally with the file browser (nautilus etc) it mounts disks by interacting with udisks behind the scenes.
You can do the same thing on the command line with the udisks tool.
/usr/bin/udisks --mount /dev/sdb1
The bit after --mount is the device name of the partition you want to mount. (/dev/something)
Finding the device name of your Partition
Open your partition in nautilus (this makes sure it's mounted) type mount in a terminal. You should see a line with your disk name on it like:
/dev/sdb1 on /media/My-Happy-Disk type vfat ....
- 1,403
- 2
- 15
- 17
I asked a duplicate of this question, and have found an answer when looking for something else. In Kubuntu 16.04, you don't need a command line instruction or to install software. Simply go to System Settngs > Removable Devices > Attached Devices and select Automount on Login. Good work by the developers!
- 347
