Possible Duplicate:
Add custom command in the open with dialog?
I want to set a filetype to be opened by a specific program other than ubuntu's default. I usually
right click > properties > open with
and select the application I need. This however does not work in this case.
The application I want is not shown in the "open with" dialog and there apparently is no way I can browse to it or type in a custom command like I used to in 10.04.
I'm aware of the above work-around which will work for each individual file but not make the app generally available from the "open with" dialog.
Is this a bug that I should file or a feature that can be worked around?
Fsando
  • 595
Try this: right click file, open with other application, then select the application in the menu.
But if you really command you can take a look at http://www.packtpub.com/article/control-of-file-types-in-ubuntu using mime you can change the default type for any extension, granted you know the command for launching it in command line.
kmassada
  • 1,396
