34
As an Ubuntu noob, I install and uninstall a lot of packages, to try them out. However, for months, I made the mistake of using apt-get remove instead of apt-get purge, which I didn't even realize exists.
Is there a way to cause apt-get to purge every package I've uninstalled? My system is full of leftover files I neither want or need from dozens of different packages.
valse-triste
  • 414
5 Answers5
36
A simpler alternative, using aptitude (not installed by default)
sudo aptitude purge '~c'
~c is an aptitude search pattern, it means 'Select packages that were removed but not purged'. (The single quotes are to prevent the possible expansion of ~c by the shell as the home directory of a user c.)
Note that purging will remove system configuration files, usually located in /etc, but personal configuration files, usually in some hidden directory in your home, are not removed (it is not always simple to know which they are).
8128
  • 28,868
enzotib
  • 96,093
15
https://help.ubuntu.com/community/AptGet/Howto says:
dpkg -l | grep '^rc' | awk '{print $2}' | xargs dpkg --purge
Beernarrd
  • 386
those two will clean your packages, but you should get in the habit of using this,
sudo apt-get remove --purge <package name>
that will purge the packages.
also check this out, this an utility called ubuntu-tweak, it has a feature that is called janitor, that lets you see the packages to clean, and even the configs. http://www.howtogeek.com/112974/how-to-customize-ubuntu-with-ubuntu-tweak/
kmassada
  • 1,396
I use Ubuntu-Tweak to do this job.
  1. Install Ubuntu tweak
  2. Open it by typing "Ubuntu-tweak" in the dash. To open dash, press Super key.
    Ubuntu tweak in dash
  3. Go to the janitor tab, Click on the Package Configs in the left bar, then put a Tick mark at the right section of window and then click the Clean button. This will ask administrative password, give it and wait for a while....... Your system is clean from old configs.
    cleaning in ubuntu tweak
Anwar
  • 77,855
As an alternative to the other answers, you can remove any leftover configuration files by using the BleachBit utility (click to install).
fitojb
  • 2,233
