I'm using Acer TimelineX from beginning of using 12.04, Compiz is crashing more than twice daily. Up to today I've been trying to solve this problem by:
  1. Using another driver and graphic card.
  2. Using newest kernel and Xorg from Quantal backports.
  3. Resetting Compiz settings and whole profile.
  4. Changing Alt+Tab button bindings (I've readed that can be related).
What can I do more to resolve this issue?
nanofarad
  • 20,906
qMic
  • 25
I had these and other problems in compiz. You can find a bug report here. In short, the solution to that particular bug was to install an alternative, older version of the packages:
sudo apt-add-repository ppa:vanvugt/compiz-preproposed
sudo apt-get update
sudo apt-get install compiz=1:0.9.7.8-0ubuntu1vvpreproposed2 compiz-core=1:0.9.7.8-0ubuntu1vvpreproposed2 compiz-gnome=1:0.9.7.8-0ubuntu1vvpreproposed2 compiz-plugins=1:0.9.7.8-0ubuntu1vvpreproposed2 compiz-plugins=1:0.9.7.8-0ubuntu1vvpreproposed2 compiz-plugins-default=1:0.9.7.8-0ubuntu1vvpreproposed2 libdecoration0=1:0.9.7.8-0ubuntu1vvpreproposed2
Restart compiz:
compiz --replace &
If that does not work better for you, the packages will be replaced during the next system update. Or just do
apt-get update
apt-get dist-upgrade
If, however, you have better experience with that older package (that was my case), you can make the change more permanent ("pin" the package at a certain version). For this, install synaptic:
apt-get install synaptic
Synaptic is an alternate package manager that also allows to pin the packages.
Alternatively, you can run:
{ echo compiz hold ; echo compiz-core hold ; echo compiz-plugins hold ; echo compiz-gnome hold ; echo compiz-plugins-default hold ; echo libdecoration0 hold ; } | sudo dpkg --set-selections
January
  • 37,208
