169
When I install the Ubuntu, I set a short password(<4). Now I want to change the other short password by "passwd" or change passphrase on "Password and Keys" program, it needs a password >4 char.
Lei Ming
  • 1,829
6 Answers6
291
Use following command in Terminal:
sudo passwd <user>
Replace <user> with the username whose password you wish to change.
This works because passwd suppresses all checks for length or entropy when you use it as the root user.
Warning: if the target user has an encrypted home directory, this will cause problems! (see comments below)
user72421
  • 3,711
44
By default, Ubuntu requires a minimum password length of 6 characters, as well as some basic entropy checks. These values are controlled in the file /etc/pam.d/common-password, which is outlined below.
password        [success=2 default=ignore]      pam_unix.so obscure sha512
If you would like to adjust the minimum length to 4 characters, add the appropriate variable (minlen=4) to the end of the line. The modification is outlined below.
password        [success=2 default=ignore]      pam_unix.so obscure sha512 minlen=4
Source.
NlightNFotis
  • 2,510
  • 17
  • 26
31
Bring up a terminal and edit /etc/pam.d/common-password
Change this line:
password    [success=1 default=ignore]  pam_unix.so obscure sha512
to:
password    [success=1 default=ignore]  pam_unix.so obscure sha512 minlen=4
Password also need a certain amount of complexity, as specified by the obscure parameter above.
password    [success=1 default=ignore]  pam_unix.so minlen=2 sha512
removes that check also.
This all presupposes that you think this is wise.
See man pam_unix
These work on my system.
John S Gruber
  • 13,436
In Ubuntu 18.04 none of other solutions worked for me. I had to replace both of these lines:
password    requisite                   pam_cracklib.so retry=3 minlen=8 difok=3 dcredit=-1 enforce_for_root lcredit=-1 ocredit=-1 reject_username ucredit=-1
password    [success=1 default=ignore]  pam_unix.so obscure use_authtok try_first_pass sha512
in /etc/pam.d/common-password with:
These changes let me changed my password easily and after changing password I restored file to it's original form.
To set up a simple password, I tried the simple sudo passwd username method, but it failed on my Ubuntu Server 12.04 LTS.
So I tried to remove the obscure option from /etc/pam.d/common-passwd config file, but it still failed.
So I also removed the obscure option from /usr/share/pam-configs/unix config file. And then it worked :-)
I do agree that it should be simplier, when acting as su to set up a weak password, whatever the reason why one wants to do it! A warning saying "weak password, confirm?" would be perfect...
Aditya
  • 13,616
This can be done with PAM pwdfile module.
The way described here changes only the desktop login (lightdm service), but can be applied to other services as well if you wish.
Also, this allows you to have your original strong password for "sudo", while maintaining a fairly easy way to login to Ubuntu desktop.
Commands can be issued in the terminal program.
Installing the software
First, we install a software package named libpam-pwdfile:
sudo apt-get install libpam-pwdfile
Creating the user-password file
We will then create the user/password file. You will be prompted to enter a new PIN password. Your password will be encrypted and saved to a file named passwd.like
pinpass=$(mkpasswd -5)
echo "$pinpass" | sudo tee /etc/passwd.like
Alternatively, you may use: openssl passwd -1 yourpinpasswordhere and create a file named /etc/passwd.like and that password.
Setting up the desktop login service
The next step is to prepare the desktop login service to accept the PIN password before other password procedures. I've mentioned already the name of the desktop login service, lightdm.
Take a look at the file:
cat /etc/pam.d/lightdm
If you don't have this file, then your desktop (login) service is a different one, and you should find your desktop manager before going further. As explained before, this guide is for Ubuntu 16.04 but can be used for other login services as well.
It could be useful if you also create a backup:
sudo cp /etc/pam.d/lightdm /etc/pam.d/lightdm.backup
Now, you may edit the file using nano or gedit or any other text editor:
sudo gedit /etc/pam.d/lightdm
At the top of the file mine had:
#%PAM-1.0
auth    requisite       pam_nologin.so
auth    sufficient      pam_succeed_if.so user ingroup nopasswdlogin
@include common-auth
I have modified it like so:
#%PAM-1.0
auth required pam_pwdfile.so pwdfile=/etc/passwd.like
auth required pam_permit.so
#@include common-auth
Save the file and close your text editor.
Log out and log back in.
You should be able to use the PIN password you set. By following this guide, the PIN password is only used for the desktop login service, not for the password of sudo commands.
Source: http://blog.radevic.com/2017/11/how-to-set-pin-password-or-short.html
