I've reinstalled Nautilus from the maverick repositories after removing nautilus-elementary and the breadcrumb hacks, but I have no longer access to the "preferences" menu and the default toolbar. How do I reset Nautilus to the default configuration?
Update: I've tried moving both ~/.nautilus and ~/.gconf/apps/nautilus folders as suggested below, but my "Edit" menu is still missing the "Preferences" item. Running the nautilus-file-management-properties applet from the command line I'm still seeing the "Tweaks" tab that nautilus-elementary added.
Solved: My problems where caused by the wrong nautilus-data package being installed. I should have replaced the nautilus-data package along with the nautilus one when removing nautilus-elementary. Before that I should have known there was a nautilus-data package ;-)
