I have a Fujitsu ScanSnap S1300i. I compiled SANE from source. When I run sane-find-scanner, the following output is given:
sane-find-scanner will now attempt to detect your scanner.
If the result is different from what you expected, first make sure your scanner
is powered up and properly connected to your computer.
No SCSI scanners found. If you expected something different, make sure
that you have loaded a kernel SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x04c5, product=0x128d) at libusb:002:004
Your USB scanner was (probably) detected. It may or may not be supported by SANE.
Try scanimage -L and read the backend's
manpage.
Not checking for parallel port scanners.
Most Scanners connected to the parallel port or other proprietary ports can't be detected by this program.
You may want to run this program as root to find all devices.
Once you found the scanner devices, be sure to adjust access permissions as necessary.
However, when I run scanimage -L or sudo scanimage -L the following output is given:
No scanners were identified. If you were expecting something different.
Check that the scanner is plugged in, turned on and detected by the sane-find-scanner tool (if appropriate).
Please read the documentation which came with this software (README, FAQ, manpages).
Also, I added an entry to /etc/sane.d/fujitsu.conf for the ScanSnap S1300i.
