There is no general log for the home folder that details when files and folders were created; the system logs record a number of things, including when software is installed, and often a hidden folder is created in the home folder when you add software, so you might be able to infer when that was created and where it came from by looking at the system logs.
On your system, files and folders are not marked with the time they were created; as you can see below with the stat command only the access (atime), modify (mtime) and inode change times (ctime) are listed.
Full output from stat ~/Downloads:
File: `/home/mike/Downloads'
Size: 53248 Blocks: 104 IO Block: 4096 directory
Device: 801h/2049d Inode: 6291653 Links: 38
Access: (0755/drwxr-xr-x) Uid: ( 1000/ mike) Gid: ( 1000/ mike)
Access: 2012-08-20 11:54:35.024905317 +0100
Modify: 2012-08-20 11:54:33.980904809 +0100
Change: 2012-08-20 11:54:33.980904809 +0100
Birth: -
You can use fuser to see what processes are accessing which folders; for example, to view those processes related to your overall home folder, enter:
fuser -v /home/mike
If you are concerned that something unauthorised is accessing your home folder I should take a look at the suggestions I made here in this article about searching for files having been modified by a person who is not your user.
Some programs create logs and these might log their activities, but they can be difficult to search as a whole without going through your entire home folder. If you want to monitor yourself you could install some software that logs and monitors everything you do.
If you want to monitor and record to file everything typed into your interactive bash terminal (including mkdir commands), you could put this clever use of the trap command into your .bashrc.
