63
I would like to install the most recent version of boto, which I do via python setup.py install
Yet when I try to remove the old version the following packages also get removed:
apt-get remove python-boto
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
  cloud-init cloud-utils euca2ools python-boto
How can I tell the package manager to remove boto, and them mark it as installed externally (or something like that) so that apt won't try to fix the missing dependency?
Alexis Wilke
  • 2,787
6 Answers6
85
Use dpkg directly, not apt-get or aptitude:
sudo dpkg --remove --force-depends "packagename-version"
or
sudo dpkg --remove --force-depends "packagename"
bfontaine
  • 197
19
I know this is an old post, but since I recently had a similar problem I would like to share my solution in the hopes that someone in the future finds it useful.
If you installed a package via aptitude it automatically assigns flags to the dependencies (auto) and when you try to remove your package again it tries to remove all its dependencies that have the auto flag still set.
As you can see in my case it's zabbix that i want to remove:
uman@mango:~$ sudo aptitude purge zabbix-server-mysql zabbix-frontend-php
  apache2{u} dbconfig-common{u} fping{u} javascript-common{u} libhtml-template-perl{u} libiksemel3{u} libjs-prototype{u}
  libjs-scriptaculous{u} libopenipmi0{u} libt1-5{u} mysql-server{u} mysql-server-5.1{u} mysql-server-core-5.1{u} php5{u} php5-gd{u}
  php5-mysql{u} snmpd{u} wwwconfig-common{u} zabbix-frontend-php{p} zabbix-server-mysql{p}
0 packages upgraded, 0 newly installed, 20 to remove and 0 not upgraded.
Need to get 0 B of archives. After unpacking 44.9 MB will be freed.
Do you want to continue? [Y/n/?]
And if we look up the apache package it looks like this
uman@mango:~$ aptitude search ^apache2
i A apache2        - Apache HTTP Server metapackage
<snip>
the first flag "i" tells us that apache is installed
The next flag "A" stands for automatically installed
So in order to fix this and not having apache, mysql and php uninstalled, we can just remove the auto flag with aptitude like this:
uman@mango:~$ sudo aptitude unmarkauto apache2 mysql-server php5
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
Now it looks like this when removing the zabbix package:
  dbconfig-common{u} fping{u} javascript-common{u} libiksemel3{u} libjs-prototype{u} libjs-scriptaculous{u} libopenipmi0{u} libt1-5{u}
  php5-gd{u} wwwconfig-common{u} zabbix-frontend-php{p} zabbix-server-mysql{p}
0 packages upgraded, 0 newly installed, 12 to remove and 0 not upgraded.
Need to get 0 B of archives. After unpacking 16.6 MB will be freed.
Please check out the man page for aptitude for more details
Karim
  • 191
17
You can create a dummy .deb package using the equivs utility, it will provide the dependency without installing any files. Then just replace the currently installed package to the dummy version using dpkg -i fake.deb.
João Pinto
  • 17,323
17
That's exactly what apt-mark hold is for.
apt-mark hold package_name
From the documentation:
hold is used to mark a package as held back, which will prevent the package from being automatically installed, upgraded or removed. The command is only a wrapper around dpkg --set-selections and the state is therefore
To unhold a package:
apt-mark unhold package_name
Marcio
  • 271
AFAIK there is no way to remove a package using APT without also removing those packages that depend on it.
Reference: http://www.debian.org/doc/manuals/apt-howto/ch-apt-get.en.html
aneeshep
  • 30,949
To complete João Pinto's answer, you can use my little script to fix broken package, this script will create dummy package with equivs and install it. You can find a article on my blog in french.
Or directly on gist code .
To use it:
$ ./gen-dummy-package.sh --install|i [packageName]+
# e.g. :
$ ./gen-dummy-package.sh -i rfkill nome-bluetooth bluez
heralight
  • 376
