200
It seems a simple apt-get remove apache2 does not completely remove apache2 as I can still see it on one of the processes when running top. How does one remove apache2 completely on his ubuntu server?
It's not removed indeed:
~# which apache2
/usr/sbin/apache2
~# whereis apache2
apache2: /usr/sbin/apache2 /etc/apache2 /usr/lib/apache2 /usr/share/apache2 /usr/share/man/man8/apache2.8.gz
But when I do apt-get remove apache2 again:
# apt-get remove apache2
Reading package lists... Done
Building dependency tree
Package apache2 is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Jürgen Paul
  • 2,167
10 Answers10
219
apache2 is a metapackage that just selects other packages. If you installed apache by installing that package, you just need to run this to clean up the automatically selected packages:
sudo apt autoremove
If that doesn't work, you might have installed one of the dependents manually. You can target all the apache2- packages from space and nuke the lot:
sudo apt remove apache2*
For future reference, to find out which package a binary is from, you can run this:
dpkg -S `which apache2`
I'd expect that to come back with apache2.2-bin (at the time of writing).
Oli
  • 299,380
205
Follow these steps to remove the apache2 service using Terminal:
  1. First stop the apache2 service if it is running with:
    sudo service apache2 stop
  2. Now remove and cleanup all the apache2 packages with:
    sudo apt-get purge apache2 apache2-utils apache2.2-bin apache2-common
    //or
    sudo apt-get purge apache2 apache2-utils apache2-bin apache2.2-common
  3. Finally, run
    sudo apt-get autoremove
just in case any other cleanup in needed
You can do the following two tests to confirm apache has been removed:
  1. which apache2 - should return a blank line
  2. sudo service apache2 start - should return apache2: unrecognized service
catch32
  • 1,286
  • 32
  • 43
89
A very simple and straightforward way that worked for me is as follows:
  1. Stop apache2.
  2. Uninstall Apache2 and its dependent packages.
  3. Use autoremove option to get rid of other dependencies.
  4. Check whether there are any configuration files that have not been removed.
    whereis apache2
  5. If you get a response as follows apache2: /etc/apache2 remove the directory and existing configuration files.
    sudo rm -rf /etc/apache2
Source: How to uninstall and remove Apache2 on Ubuntu or Debian by Dan Nanni
CStanda
  • 991
For a Debian based OS, like Ubuntu, use:
sudo apt remove --purge apache2
sudo apt autoremove -y
Nmath
  • 12,664
MD SHAYON
  • 415
Remove apache2 from the Ubuntu
To remove totally from your localhost
1st check the current status using
service apache2 status
if it's active (running) write next
Say yes using y.
Kulfy
  • 18,154
Euclid.H
  • 235
First check if you are using right package name, IMO correct package name is : apache2.x-common
If you want to completely remove the package including config files then try:
    dpkg --purge apache2.2-common
Amol Sale
  • 1,043
I tried the other answers here but this is the most complete solution I have found which worked for me:
$ sudo service apache2 stop
$ sudo apt-get purge apache2 apache2-utils apache2.2-bin apache2-common
$ sudo apt-get autoremove
The output of the below command will provide you with information the installed package software, version, architecture and short description about the package. grep command is used to find the apache package
$ sudo dpkg --get-selections | grep apache | cut -f 1
$ sudo apt-get remove --purge <package name from the previous command output>
$ sudo whereis apache
$ sudo rm -rf <directory/file path from the previous command output>
see http://www.xavierdilipkumar.com/post/how-to-uninstall-php-apache-and-mysql-on-ubuntu
Take time to check if you are using the different package apache2.2-bin for Ubuntu 16.04 the latest is apache2.4-bin
sudo apt-get purge apache2 apache2-utils apache2.4-bin apache2.4-common
pensebien
  • 171
Use this to delete installation and its dependencies. It will also reload the firewall
sudo dpkg --purge apache2
sotirov
  • 4,379
These commands will completely remove Apache2, all its configs, logs and www files.
sudo apt purge apache2
sudo apt purge apache2-utils
sudo apt autoremove
sudo rm -rf /var/lib/apache2
sudo rm -rf /var/log/apache2
And if you want to remove all www files too,
sudo rm -rf /var/www/html
WARNING: sudo rm -rf /var/www/html will delete all files in your /var/www/html directory, make sure you don't have anything important there!!!
sotirov
  • 4,379
