Can someone give me a hand with a HD 4650 SAPPHIRE driver? I searched on the official site and this is what I get:
AMD Catalyst™ Driver for AMD Radeon™ HD 4000, HD 3000 and HD 2000 Series
AMD has moved to the AMD Radeon™ HD 4000, AMD Radeon HD 3000, and AMD Radeon HD 2000 Series new driver support model.(...)
Applicable Products:
This article applies to the following configuration(s): Hardware:
AMD Radeon HD 4000 Series / AMD Radeon HD 3000 Series / AMD Radeon HD 2000 Series / AMD Radeon HD Series AGP / AMD Mobility Radeon HD 4000 Series / AMD Mobility Radeon HD 3000 Series / AMD Mobility Radeon HD 2000 Series /
And a link to a single driver: AMD Catalyst™ 12.6 Proprietary Linux x86 Display Driver (Automated installer and Display Drivers for X.Org 6.7, 6.8, 6.9, 7.0, 7.1, 7.2, 7.3, 7.4, 7.5, or 7.6)
Last time I installed this driver it gaved me some error (can't remember what it was) and I couldn't install nothing no more due to some FGLRX & dpgk error. Any solutions?
You need to remove all the current fglrx packages from your system
if any of these returns errors ie: file not found, package not found ignore it
Type in terminal Ctrl-Alt-T
sudo sh /usr/share/ati/fglrx-uninstall.sh
sudo apt-get remove --purge fglrx fglrx_* fglrx-amdcccle* fglrx-dev*
Once this is done follow these instructions to install the correct driver from the officical AMD site
OR
If you want to install the Official ubuntu binarys go-to System Settings >> Additional Drivers and select the Driver thats recommended
stephenmyall
  • 9,885
Open the Dash,
Search for Additional Drivers.
Open it.
And Activate the driver if necessary.
stephenmyall
  • 9,885
Steiger
  • 7,857
If Varun's suggestion fails (in my case it did) you can install the drivers manually.
A nice step-by-step explanation can be found at http://wiki.cchtml.com/index.php/Ubuntu_Installation_Guide
