Installed 12.04 on a new HP Pavilion desktop p7-1235 (AMD A8-5500 APU). Volume is very low from external speakers and headphones plugged into the front jack. I set the master volume and speaker/headphone volumes to max, but volume is very low. Used alsamixer to set everything to max, unmuted, same result.
Asked
Active
Viewed 3,127 times
Try installing pavucontrol:
sudo aptitude install pavucontrol
It might be that an output device has its volume low and the volume indicator doesn't control it (i.e. when you increase/decrease the volume, this only affects one sink only)
ivotron
- 303
There's a chance that your sound card might not be driving enough electricity to up the volume. If it goes lower when you reduce it, this may be a good indicator of that.
The best suggestion would be to get a set of externally powered headphones/speakers.
Source: I had an HP DV-9000 with the same issue about 2 years ago.
D'Lano
- 79
- 1
- 5
I'm not sure if you have done it yet, but try either
new headphone maybe?
maybe you could try another version of ubuntu, possibly 12.10? Or 12.04 LTS?
Kyle Macey
- 1,679
Jordan
- 793
