69
I tried running mysql in my terminal and I got:
The program 'mysql' is currently not installed.  You can install it by typing:
sudo apt-get install mysql-client-core-5.5
But when I do:
I get:
Reading package lists... Done
Building dependency tree
mysql-client-core-5.5 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 47 not upgraded.
Running ls -l /usr/bin/mysql returns:
ls: cannot access /usr/bin/mysql: No such file or directory
How should I proceed?
batman
  • 8,071
First, remove the current version of MySQL you're already using:
$ sudo apt-get purge mysql-client-core-5.5
Now, to install MySQL, run the following command from a terminal prompt:
$ sudo apt-get install mysql-server
$ sudo apt-get install mysql-client
During the installation process you will be prompted to enter a password for the MySQL root user.
Once the installation is complete, the MySQL server should be started automatically. You can run the following command from a terminal prompt to check whether the MySQL server is running:
$sudo ss -tlp | grep mysql
When you run this command, you should see the following line or something similar:
LISTEN 0      80                 *:mysql            *:*    users:(("mysqld",pid=898368,fd=20))
If the server is not running correctly, you can type the following command to start it:
$ sudo /etc/init.d/mysql restart
You can edit the /etc/mysql/my.cnf file to configure the basic settings: log file, port number, etc.
Daniel T
  • 5,339
TomKat
  • 3,878
24
This command installs the MySQL server, which you need.
If you want to run commands from the workbench and not from a terminal, you need the client as well (this is optional):
For MySQL Workbench (also optional):
sudo apt-get install mysql-workbench
Zanna
  • 72,312
Mihai
  • 1,674
10
First you have to remove MySQL completely from your system using following commands in a terminal:
sudo apt-get remove --purge mysql-server mysql-client mysql-common
sudo apt-get update && sudo apt-get upgrade
sudo apt-get autoremove
sudo apt-get autoclean
Now try to reinstall MySQL.
KK Patel
  • 19,753
That suggestion seems a little bizzare because it would miss out other dependencies and utilities. I would just run this and be done with it:
Oli
  • 299,380
