26
I recently had to copy about 20 GB of data split between about 20 files from my laptop to an external hard drive. Since this operation takes quite a while (at ~560kb/s), I was wondering if there was any way to pause the transfer and resume it later (in case, I need to interrupt the transfer). As a side question, is there any performance difference between copying from the terminal vs copying from Nautilus?
I would recommened using rsync.
Example:
rsync -a --append source-file destination
If you want to see the progress, add the --progress option to the command.
alt text
Jorge Castro
  • 73,717
Isaiah
  • 60,750
short answer, need no installation, to pause use kill -STOP PID
to continue paused process use kill -CONT PID
where PID is Process ID. you can get PID by running System monitor or top command
Alex Jones
  • 8,192
I can answer only the part about the difference between terminal and nautilus. I have checked several times this. It appears copying from terminal is faster than any graphical way like nautilus. At least in my case, when i copy about 32GB of info, it takes about 3 to 5 minutes less from terminal than nautilus from a 25 minute copy. that is about 10%-20% of the time. About a way to resume a copy to your external unit i think curl or rsync would resume a failed copy. At least with cp command. I have not tried this myself (I will try tomorrow) but this two might work.
For curl you need to aptitude install curl or apt-get instal curl since it does not come with ubuntu by default.
Use curl --help or rsync --help to find out more. Tomorrow i will show how to copy with both if you could not find the way.
d a i s y
  • 5,551
Luis Alvarado
  • 216,643
I would also recommend rsync, but with the --partial option, this way it checks the already transferred data. You could even use it to repair a more or less fully transferred file which has a corruption somewhere in between.
rsync -v --info=progress2 --partial source destination
Alex
  • 1,062
