Possible Duplicate:
How to I remove windows but keep Ubuntu?
I have successfully installed Linux Ubuntu 12.04 of my computer with the USB boot method. When I installed Ubuntu, I selected the option where it lets you keep windows on the computer in a separate partition so that you can have both Linux and windows as operating systems in the computer. Well, I decided I no longer need Windows, and I very much want to remove it so Linux has more space. Can I remove windows at this point and allocate more space for Linux, and if so, how can this be done? Thank you.
I just thought I would write a clearer, and more noob friendly version of the others answers. :)
Steps are:
  1. Open Disk Utility (Go to menu and search for it).
  2. Identify your Windows partition. It should be a NTFS filesystem.
  3. If mounted, click the "Unmount disk" button.
  4. Click the "Format disk" button.
  5. Choose Ext4 from the dropdown list.
  6. Choose a name for the partition.
  7. Make sure that, the "Take ownership of filesystem" checkbox is ticked, and that the "Encrypt underlying device" checkbox is not.
  8. Click format.
Edit: Step 9: Open a terminal, by either searching for it in the menu or pressing CTRL + ALT + T, and type update-grub and press enter.
  1. Enjoy! :)
(Thanks to John S Gruber for Step 9.)
snoop
  • 4,110
  • 41
  • 58
Just go to Disk Utility. Identify Windows partition properly and delete it. You can format it as Linux partition.
Once done, in terminal type the following:
sudo grub-install /dev/sda
sudo update-grub
When done, reboot the machine.
jokerdino
  • 41,732
KK Patel
  • 19,753
Just Go to Disk Utility. Identify windows partition properly format it as Linux partition.
Once done in terminal ( What is a terminal and how do I open and use it? ) type:
sudo update-grub
When done reboot the machine.
Amit Rane
  • 1,310
