After a clean install of edubuntu 12.04 on an Acer AO531-h netbook, restart doesn't work. The process starts normally but just before it shuts down the netbook freezes and I have to force shut down. The command "sudo reboot" has the same problem. I have no issues with shut down, only with restart. I'm absolute beginner.
Netbook specs: Acer, intel atom CPU N270 @1.60GHz, 1.05 GHz 0.98GB RAM Dual booting with windows xp. No problems with windows.
Ket
1) Open the terminal and run this command to edit grub file:
sudo gedit /etc/default/grub
2) Find this line in the file:
GRUB_CMDLINE_LINUX=""
3) Change its value like this:
GRUB_CMDLINE_LINUX="reboot=bios"
4) Save the file
5) Update Grub by running this command in terminal:
sudo update-grub
6) Reboot your Netbook. Everything must be fine now.
Peachy
  • 7,235
  • 40
  • 47
GMTech
