I've been using Ubuntu 12.04 on my Macbook Air 3,1 (11", late 2010 model) and it's been working well, after applying the post-installation patches found on the wiki.
Yesterday (July 24, 2012), after doing an apt-get dist-upgrade, I noticed a glitch with the LCD screen: there is a vertical row of colored pixels that moves from top to bottom, with a marquee-like effect.
I do not think this is a hardware problem, since it does not appear when I boot the computer into MacOS.
The glitch is about 2 mm from the right edge of the screen, so it is not too noticeable (there's usually a scroll bar there), but I still would like to make it disappear.
I did a brief Google search for this problem but haven't found anything yet. Can you suggest how I can investigate and hopefully fix this?
I've got exactly the same issue here on the MBA 2010 late 11' thus it might be model-specific. It appeared after the last update as you described.
after playing around a bit ... here is what worked for me.
I installed the nvidia-current drivers from the softwar center... After a reboot X was started with the nvidia drivers and the problem was gone. BUT ... the brightness controls were gone too...
Adding the line
Option "RegistryDwords" "EnableBrightnessControl=1" in the Section "Device" of /etc/X11/xorg.conf solved that issue.
See: Brightness not working after installing NVIDIA driver and http://ubuntuforums.org/showthread.php?t=1973581 for more information.
SGMD
  • 36
