23
I'm trying to remove a package where I deleted the /etc/init.d/disco-master file (in an attempt to remove the package manually). I want to remove the disco-master package. How do I do this now?
This is what happens when I do sudo apt-get remove disco-master:
removing disco-master ...
invoke-rc.d: unknown initscript, /etc/init.d/disco-master not found.
dpkg: error processing disco-master (--remove):
 subprocess installed pre-removal script returned error exit status 100
 disco-master
When I do sudo apt-get install --reinstall disco-master I get the following:
You might want to run 'apt-get -f install' to correct these:
 disco-master : Depends: disco-node (= 0.4.2+nmu1) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
When I do sudo apt-get -f install I get this:
Unpacking disco-node (from .../disco-node_0.4.2+nmu1_amd64.deb) ...
dpkg: error processing /var/cache/apt/archives/disco-node_0.4.2+nmu1_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/disco/master/ebin/disco.app', which is also in package disco-master 0.4.1
No apport report written because MaxReports is reached already
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
When I run sudo apt-get remove disco-node I get the following:
Package disco-node is not installed, so not removed
 disco-master : Depends: disco-node (= 0.4.1) but it is not going to be installed
                Depends: python-disco (= 0.4.1) but 0.4.2+nmu1 is to be installed
When I did sudo dpkg -P --force-all disco-master I got:
Removing disco-master ...
dpkg: error processing disco-master (--purge):
 disco-master
Eric Carvalho
  • 55,453
fodon
  • 333
Create a dummy initscript to fool dpkg:
sudo nano /etc/init.d/disco-master
Enter the following:
#!/bin/bash
exit 0
Save the file, set execution permission (sudo chmod 755 /etc/init.d/disco-master) and try to sudo apt-get remove disco-master again.
Eric Carvalho
  • 55,453
