-1
I removed TIMESHIFT on Ubuntu and I followed the instructions in Timeshift - GitHub's ReadMe but after a succesfull removal it gives me this error, how can I delete this script?
Rsyncing /boot/efi into the filesystem before the call to timeshift.
/usr/bin/timeshift-autosnap-apt: riga 54: timeshift: comando non trovato
Unable to run timeshift-autosnap-apt! Please close Timeshift and try again. Script will now exit...
E: Problem executing scripts DPkg::Pre-Invoke '/usr/bin/timeshift-autosnap-apt' E: Sub-process returned an error code
andrew.46
  • 39,359
glawon
  • I went to /usr/bin/
  • Found timeshift-autosnap-apt
  • Deleted it
  • Ran the command:
    sudo nano /usr/bin/timeshift-autosnap-apt
  • Entered the following:
    #!/bin/bash
    exit 0
  • Saved the file
  • Set execution permission:
    sudo chmod 755 /usr/bin/timeshift-autosnap-apt
And sudo apt upgrade ignored the script and worked succesfully.
Source that helped me to find the solution: How to force remove a package if dpkg removal script fails?
Answer moved here from OP's question.
