11
I have changed base theme and made also some modifications (change fonts, sizes, icons sets etc)
I would like to save all and test some other themes and restore them back.I'm using 12.04.
Is this possible ?
Anwar
  • 77,855
Nikos K.
  • 111
I have found a way to save and restore theme settings. Actually It restores all your personalized settings.
To Backup
Open a terminal and do this
cp ~/.config/dconf/user  ~/settings-backup
cp -r ~/.gconf/apps/metacity ~
This will copy the user settings in your home directory in a file named settings-backup. The window manager theme (window framing) will be stored in a folder named metacity in the home folder
To Restore
Open a terminal and do this (I assume your backup file is in your home folder with the name settings-backup)
cp ~/settings-backup ~/.config/dconf/user
cp -r -v ~/metacity ~/.gconf/apps
This will restore the theme settings and the window manager settings. (Note that, If you delete a theme, it can't restore that theme)
Logout and Login again, to see all your settings are restored.
Anwar
  • 77,855
All your configuration and preferences are store in your /home folder, as a hidden folder. If you backup your home folder you'll be able to restore to your previous configuration. For example, I use Lubuntu 12.04 and have a hidden folder in ~/.config/openbox with some of my system settings.
Related: How to migrate user settings and data to new machine?
