15
I have an iPhone and run Ubuntu on all of my personal computers. Since I did not want to keep a separate partition with Windows on it for the sole purpose of running iTunes, I attempted to install It using Wine.
I installed Wine 1.4 from the Software Center and installed iTunes 10.6.3. When I tried to run it I got a slew of error messages. I hopped over to google where it was suggested that I install it through PlayOnLinux. I did so with the same result. Further googling revealed that iTunes 10.6.x is confirmed to work with Wine 1.5.1 and up.
I installed Wine 1.5.1 following the instructions I found and was unable to get it to open. I did the same with 1.5.9 with the same results. I opened the Package Manager and installed the Wine 1.5.9 packages through it, and it appears to have installed properly.
When trying to install iTunes I got he error "This iTunes installer requires Windows Vista 64 bit or later". Realizing that Wine uses XP as a default I ran winecfg and changed it to Windows 7. This changed nothing and I tried changing it through winetricks to no avail. I even changed it to Vista with the same results.
Does anyone know what is going wrong here and how to fix it? Thanks
fossfreedom
  • 174,526
David
  • 151
Unfortunately Apple does not support the Linux platform when it comes to their products. Even if you manage to install iTunes with wine, it won't work like it would say on a Mac or Windows set up.
Rythmbox and many Linux media players (from personal experience) will be able to snyc and play your songs without a problem.
The best option for you is to install Virtualbox and install Windows your guest OS, iTunes should install and work your iPhone.
Here is a guide on how to install Windows XP on Ubuntu with Virtualbox.
However (from personal experience) do not try updating the firmware of your phone with virtualbox as it does not work like on a native OS.
Tim
  • 33,500
Mysterio
  • 12,288
To prevent iTunes from detecting a 64bit environment, see this guide: How to force Wine into acting like 32-bit Windows on 64-bit Ubuntu?
Basically:
  • remove ~/.wine
  • export WINEARCH=win32
  • wine iTunesXYZSetup.exe
Sven
  • 31
