I had no problems using my Windows Media Center Remote with 10.10 Mythbuntu, but after upgrading, it no longer affects Mythbuntu.
I have verified and re-installed it in Mythbuntu Control Centre.
I have used irw to verify the ir buttons actions are properly received by the HTPC.
How do I go about fixing this?
3.2.0-26-generic (#41-Ubuntu SMP Thu Jun 14 17:49:24 UTC 2012) Xorg version: 1.11.3 (16 July 2012 08:06:31PM) GCC: 4.6 (x86_64-linux-gnu) Current updates as of 2012‧07‧21
$cat /etc/lirc/hardware.con
#Chosen Remote Control
REMOTE="Windows Media Center Transceivers/Remotes (all)"
REMOTE_MODULES="lirc_dev mceusb"
REMOTE_DRIVER=""
REMOTE_DEVICE="/dev/lirc0"
REMOTE_SOCKET=""
REMOTE_LIRCD_CONF="mceusb/lircd.conf.mceusb"
REMOTE_LIRCD_ARGS=""
#Chosen IR Transmitter
TRANSMITTER="None"
TRANSMITTER_MODULES=""
TRANSMITTER_DRIVER=""
TRANSMITTER_DEVICE=""
TRANSMITTER_SOCKET=""
TRANSMITTER_LIRCD_CONF=""
TRANSMITTER_LIRCD_ARGS=""
#Enable lircd
START_LIRCD="true"
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD="false"
#Try to load appropriate kernel modules
LOAD_MODULES="true"
# Default configuration files for your hardware if any
LIRCMD_CONF=""
#Forcing noninteractive reconfiguration
#If lirc is to be reconfigured by an external application
#that doesn't have a debconf frontend available, the noninteractive
#frontend can be invoked and set to parse REMOTE and TRANSMITTER
#It will then populate all other variables without any user input
#If you would like to configure lirc via standard methods, be sure
#to leave this set to "false"
FORCE_NONINTERACTIVE_RECONFIGURATION="false"
START_LIRCMD=""
# lsusb | grep -i infrared
Bus 003 Device 002: ID 0471:0815 Philips (or NXP) eHome Infrared Receiver
