I upgraded mythbuntu 11.10 to mythbuntu 12.04. I had a working MCE usb remote suspend/wakeup thing going for me. After the upgrade wake on usb does not work. The light on the usb ir-receiver does not flash either when trying to wake up. The computer resumes well with the power button.
I have the following in my /etc/rc.local:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
sudo sh -c "echo USB0 > /proc/acpi/wakeup"
sudo sh -c "echo USB1 > /proc/acpi/wakeup"
sudo sh -c "echo USB2 > /proc/acpi/wakeup"
sudo sh -c "echo USB3 > /proc/acpi/wakeup"
sudo sh -c "echo enabled > /sys/bus/usb/devices/3-1/power/wakeup"
exit 0
lsusb:
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 0471:0815 Philips (or NXP) eHome Infrared Receiver
Bus 003 Device 003: ID 195d:7777 Itron Technology iONE Scorpius wireless keyboard
cat /proc/acpi/wakeup
Device S-state Status Sysfs node
P0P1 S4 *disabled pci:0000:00:1e.0
P0P4 S4 *disabled pci:0000:00:1c.0
P0P5 S4 *disabled pci:0000:00:1c.1
P0P6 S4 *disabled pci:0000:00:1c.2
P0P7 S4 *disabled
P0P8 S4 *disabled
P0P9 S4 *disabled
USB0 S3 *enabled pci:0000:00:1d.0
USB1 S3 *enabled pci:0000:00:1d.1
USB2 S3 *enabled pci:0000:00:1d.2
USB3 S3 *enabled pci:0000:00:1d.3
EUSB S3 *enabled pci:0000:00:1d.7
I have a similar problem with identical hardware on an Ubuntu install. After the upgrade on that, wake on usb keyboard doesn't work.
What I don't get is why it worked before the upgrade? What has changed?
