I followed the instructions from enzotib's answer on Making Ctrl+C copy text in gnome-terminal? to make the ctrl-c and ctrl-v keys act consistent in the terminal and then re-assign ctrl-j to be the cancel/interrupt key for ongoing processes.
The instructions works great...until I close the terminal. Next time I open the ctrl-j has to be re-assigned. I don't want to have to type out
stty intr ^J
each time I open terminal. How do I make that key assignment stick?
snowguy
  • 6,310
Assuming you are concerned only with terminals opened from the desktop (e.g. gnome-terminal ), just add stty intr ^J to your .bashrc.
  • Run this command once in a terminal:
    echo stty intr ^J \ >> ~/.bashrc
  • Close that terminal; the assignment should now stick in every gnome-terminal you open
ish
  • 141,990
