18
I'm on Ubuntu 10.10, and I've just upgraded opencv to 2.4.2.
The problem is that each time I open a new shell and try to compile and run, it compiles but doesn't run due to the following error:
./a.out: error while loading shared libraries: libopencv_calib3d.so.2.4: cannot open shared object file: No such file or directory
As far as I can see, this file is located in /usr/local/lib/!
I can get it to run by running the following beforehand:
export LD_LIBRARY_PATH=/usr/local/lib
How can I fix this issue?
Flyk
  • 1,480
  • 18
  • 24
nkint
  • 2,065
/usr/local/lib is not in the default Ubuntu path. You should add it at the end of the LD_LIBRARY_PATH environment variable in /etc/environment. Reboot and the new path will be effective.
You can also set this on a per-user basis in ~/.bashrc
Example (/etc/environment)
LD_LIBRARY_PATH=/lib:/usr/lib:/usr/local/lib
Example (~/.bashrc)
export LD_LIBRARY_PATH="/lib:/usr/lib:/usr/local/lib"
ish
  • 141,990
