I am building the vm for squeak on Ubuntu 14.04 32-bit. It is failing to call entry points to libraries, whether these libraries are statically linked or loaded or not loaded. I have been doing some research through other questions and found 4 related questions, but neither an exported LD_LIBRARY_PATH, nor running 'sudo ldconfig' helps:
I noticed this calling dynamic linked libraries squeak also builds, then it fails to find a display driver wwe also build. (More at squeakvm.org).
$ squeak Mushroom.1.image &
[2] 3107
$ squeak: could not find any display driver
[2]+ Aborted (core dumped) squeak Mushroom.1.image
I also build several of our plugins internally and these also failed to be called at runtime. Doing a nm -a squeak gave many symbols, but some, not all, of the symbols from various statically linked libraries were present.
Could an issue with symbol binding be affecting both static and dynamic cases? Are there other reports of problems with library runtime and other recommendations?
Update:
Here are the libraries I've loaded to a fresh install of 15.10 32-bit.
INSTALL BUILD LIBRARIES
sudo apt-get install cmake zip bash-completion git
sudo apt-get install libc6-dev:i386 libasound2:i386 libasound2-dev:i386 libasound2-plugins:i386
sudo apt-get install libssl-dev:i386 libssl0.9.8:i386 libfreetype6-dev:i386
sudo apt-get install libx11-dev:i386 libsm-dev:i386 libice-dev:i386
sudo apt-get install build-essential gcc-multilib g++
sudo apt-get install libgl1-mesa-dev libgl1-mesa-glx:i386
sudo apt-get install binutils:i386 g++-4.6:i386 gcc-4.6:i386
sudo ln -s /usr/lib/i386-linux-gnu/mesa/libGL.so /usr/lib/i386-linux-gnu/libGL.so
sudo ln -s /usr/lib/i386-linux-gnu/mesa/libGL.so.1 /usr/lib/i386-linux-gnu/mesa/libGL.so
sudo apt-get install uuid-dev:i386
sudo apt-get install subversion
where squeak fails to find the display driver after running sudo ldconfig -v. Something in there is breaking, I believe. I will do another install and not run any of these and slowly start a little at a time.
regards, robert
Robert
