when trying to customize my ubuntu desktop live iso i'm coming across an rsync error in the first stages of the tutorial.
when I execute:
sudo rsync --exclude=/casper/filesystem.squashfs -a mnt/ extract-cd
The copy starts with no output. I left this running for around 40 minutes and have assumed that something went wrong in the copy.
sudo rsync -ax mnt/ extract-cd I tried this command too and I got the same error after pressing ctrl+c.
This is the error I am getting:
    rsync error: received SIGINT, SIGTERM, or SIGHUP (code 20) at rsync.c(549) [sender=3.0.9]
any suggestions/tips would be welcome
Edit
This is the link to the output from the command you suggested I run:rsync output
I looked at your recommendation of using ubuntu-builder. I am using ssh to access the computer with no possibility of using an UI.
I tried the ubuntu customization kit this morning running the by running the uck-remaster-unpack-iso. My understandinf of this command is that it runs a script similar to what I was typing in by hand. This command also stops producing output and I exited it after 10 minutes(No error output was given).
The error is simply caused by your pressing Ctrl+C to interrupt rsync.
The command should work; since it's not, please try running this and let us know what the output is:
sudo rsync --exclude=/casper/filesystem.squashfs -a -nPh mnt/ extract-cd
The only difference is the additional -nPh option: - -n indicates a dry run, or a simulation; rsync will simulate what happens, including any errors, without actually copying any data. - -Ph shows the progress file-by-file in "human" readable (i.e. kilobytes, megabytes, etc.) form.
Please note: The Ubuntu customization wiki is terribly outdated. I highly recommend usin a more modern, user-friendly customization solution that takes care of extracting, mounting, chrooting, etc. for you.
Ubuntu Builder is my tool of choice. Please see this answer of mine for a more-hands-on tutorial of using Ubuntu Builder to customize 12.04.
ish
  • 141,990
After installed below packages, the problem solved.
sudo apt-get install libgcrypt11
sudo apt-get install libgcrypt11:i386
I believe I found the problem, There is another problem on my computer causing very low write speeds to ntfs. Therefore When I tried to run rsync the copy simply would not complete in a feasible amount of time.
