My boot in windows is damaged, i've tried several things and every time (even when i'm trying to format with a clean installation of windows 7, repair disc win7 doesn't work either) i try it gets to a black screen only with the mouse arrow. i installed ubuntu 12.04 via usb stick and everything is working fine, apart some bad sectors 22 that ubuntu states - probably the errors are from there. I would like to know if there is any program like chkdsk.exe in windows to search and repair the hdd (i've already tried disc utility but never gets to the end-i wanted more than 10 hours not even the small check and from command prompt aswell)
There is a very good tool called testdisk.
With testdisk you can see bad sectors, repair them, repair whole hard disk drives and you can restore whole file systems (data restore).
I have tested the tool and can say that it is very good.
slashcrack
  • 1,083
