49
it says missing bootmngr or something like that. I'm on ubuntu 12.04 or whatever, the newest one using the gparted to format to NTSC and then unetbootin to install the bootloader, and the iso, then restart. also, i do not know how to use terminal or code..and im also using an external hardrive because this laptop is missing one...
Braiam
  • 69,112
JoeMech
  • 519
That worked for me.
  • Format your USB as FAT32 in GParted
  • Open UNetbootin and get it as far as the stage where it brings up the USB partition to install to e.g. /dev/sdb1Don't install the ISO, though
  • Leaving UNetbootin open as is, switch to GParted
  • Format the USB in GParted as NTFS
  • If GParted doesn't automatically add the "boot" flag, add it yourself
  • Exit GParted, mount USB by running sudo mount /dev/sdb1 /mnt (don't forget to replace sdb1 with your one)
  • Now, go back to UNetbootin, which you've left open in the meantime, and click OK
Doing so, UNetbootin will think you are using a FAT32 partition and will let you use NTFS format.
Miha_x64
  • 105
Evildef
  • 841
If Windows is what you're trying to install, then Windows 7 bootable USB DVD download tool from Microsoft (Also works on XP) allows you to create a bootable version of windows 7 OS for installing windows through USB drive. To download this utility click Here.
Note: You need to run this on a windows machine.
For more information see Windows 7 USB Creator
Now to create a bootable Windows 7 USB Drive while using Ubuntu, then you need to make sure you have a Windows 7 .ISO file (you can create it from the DVD) and a 4GB USB flash drive (or larger).
Install Gparted and format the USB drive to NTFS. In Ubuntu, use the following command to install Gparted:1
sudo apt-get install gparted
To be able to format a drive to NTFS, you'll also need ntfs-3g - install it using the following command:1
sudo apt-get install ntfs-3g
1Source:Create A Bootable Windows 7 USB Drive From Ubuntu
Updated to add the way to create it using Ubuntu from the Source.
Install Gparted and format the USB drive to NTFS. to install Gparted:
sudo apt install gparted
To format the usb flash drive drive NTFS, install ntfs-3gt to install just type the command below in terminal
sudo apt install ntfs-3g
download TESTED Unetbootin version 494 from Here
Once downloaded navigate to the folder where the file was downloaded, most likley the Downloads folder, and open terminal there. Just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo chmod +x ./unetbootin-linux
sudo ./unetbootin-linux-494
or
sudo add-apt-repository ppa:gezakovacs/ppa
sudo apt-get update
sudo apt install unetbootin
Once installed. open UNetbootin, select "Diskimage" and then browse for your Windows 7 ISO file.
Mitch
  • 109,787
