Possible Duplicate:
How do I remove kubuntu-full and all it's applications?
I installed the kubuntu-desktop on Ubuntu 12.04. I promptly removed it, the applications it installed are still there but that's not matter. But I can still choose Kubuntu Plasma Desktop during login. Clearly I haven't removed it completely. I went to the Ubuntu Software Centre and removed it from there. Then I did the removal process from here. I did:
sudo apt-get install -y ppa-purge
sudo ppa-purge ppa:kubuntu-ppa/backports
sudo apt-get -f -y autoremove
Still there. How do I remove it completely? Thanks.
UPDATE: @xlukask
I did the command and got this output:
 Reading package lists... Done
Building dependency tree
Package ktorrent is not installed, so not removed
Package ktorrent-data is not installed, so not removed
Package kubuntu-desktop is not installed, so not removed
Package libktorrent-l10n is not installed, so not removed
Package libktorrent3 is not installed, so not removed
Package plymouth-theme-kubuntu-logo is not installed, so not removed
Package plymouth-theme-kubuntu-text is not installed, so not removed
Package dolphin is not installed, so not removed
Package ktimetracker is not installed, so not removed
The following information may help resolve the situation:
 icedtea-netx : Depends: openjdk-6-jre (>= 6b23~pre10~) but it is not going to be installed or
                         openjdk-7-jre but it is not going to be installed
 libatk-wrapper-java : Depends: default-jre but it is not going to be installed or
                                java2-runtime
 libatk-wrapper-java-jni : Depends: default-jre but it is not going to be installed or
                                    java2-runtime
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
jaorizabal
  • 3,778
