26
I think middle mouse button emulation was disabled by default in the last release. I'm sure this is a silly question but I can't find a generic answer, they all seem to be touchpad specific (ie, multi-touch related, which I don't have), or using what I consider not to be normal ubuntu methods (creating xorg.conf file). I'm using xubuntu variant (xfce) on a dell inspiron mini.
I was actually just testing there and if I tap with both fingers at once it brings up a context menu (like right click). Wired I didn't know this trackpad could even tell that there was a two finger tap...
Former behaviour was clicking both touchpad buttons (they are the built in kind) at the same time produced a middle clicck. They no longer do this. I never used a double tap, but the actual buttons.
To clarify I am using a built in Touchpad, not an external mouse. Gpointings detects it as synaptic touch, which I believe is correct
Update- The question @medigeek linked to below let me set a two fingered tap to emulate a middle click, but I still cant click both buttons at the same time
output from synclient is here:
LeftEdge                = 1760
RightEdge               = 5302
TopEdge                 = 1639
BottomEdge              = 4479
FingerLow               = 25
FingerHigh              = 30
FingerPress             = 256
MaxTapTime              = 180
MaxTapMove              = 232
MaxDoubleTapTime        = 180
SingleTapTimeout        = 180
ClickTime               = 100
FastTaps                = 0
EmulateMidButtonTime    = 0
EmulateTwoFingerMinZ    = 282
EmulateTwoFingerMinW    = 7
VertScrollDelta         = 105
HorizScrollDelta        = 105
VertEdgeScroll          = 1
HorizEdgeScroll         = 0
CornerCoasting          = 0
VertTwoFingerScroll     = 0
HorizTwoFingerScroll    = 0
MinSpeed                = 1
MaxSpeed                = 1.75
AccelFactor             = 0.0378931
TrackstickSpeed         = 40
EdgeMotionMinZ          = 30
EdgeMotionMaxZ          = 160
EdgeMotionMinSpeed      = 1
EdgeMotionMaxSpeed      = 422
EdgeMotionUseAlways     = 0
TouchpadOff             = 0
LockedDrags             = 0
LockedDragTimeout       = 5000
RTCornerButton          = 2
RBCornerButton          = 3
LTCornerButton          = 0
LBCornerButton          = 0
TapButton1              = 1
TapButton2              = 3
TapButton3              = 0
ClickFinger1            = 1
ClickFinger2            = 1
ClickFinger3            = 0
CircularScrolling       = 0
CircScrollDelta         = 0.1
CircScrollTrigger       = 0
CircularPad             = 0
PalmDetect              = 0
PalmMinWidth            = 10
PalmMinZ                = 200
CoastingSpeed           = 20
CoastingFriction        = 50
PressureMotionMinZ      = 30
PressureMotionMaxZ      = 160
PressureMotionMinFactor = 1
PressureMotionMaxFactor = 1
ResolutionDetect        = 1
GrabEventDevice         = 1
TapAndDragGesture       = 1
AreaLeftEdge            = 0
AreaRightEdge           = 0
AreaTopEdge             = 0
AreaBottomEdge          = 0
HorizHysteresis         = 26
VertHysteresis          = 26
ClickPad                = 1
RightButtonAreaLeft     = 0
RightButtonAreaRight    = 0
RightButtonAreaTop      = 0
RightButtonAreaBottom   = 0
MiddleButtonAreaLeft    = 0
MiddleButtonAreaRight   = 0
MiddleButtonAreaTop     = 0
MiddleButtonAreaBottom  = 0
muru
  • 207,228
Rqomey
  • 556
7 Answers7
18
GUI solution
Install the package gpointing-device-settings
Description-en: configuration tool for pointing devices
 GUI tool for setting pointing devices. Currently it can configure mouse type
 device (mouse, trackpoint etc.) and touchpads.
 For mouse you can configure middle button emulation, wheel emulation and
 scrolling.
 It can enable and disable touchpad, or scrolling on it as well as additional
 parameters like palm detection, locked drags, tapping and scrolling.
 It is a successor of GSynaptics.
gpointing-device-settings middle mouse button emulation
Console/terminal solution #1
Alternatively, try this:
gsettings set org.gnome.settings-daemon.peripherals.mouse middle-button-enabled true
The alternative solution might require the installation of gnome-settings-daemon package.
Console/terminal solution(s) #2
Using synclient command you can view your synaptics touchpad options.
  1. Run synclient and see what variables you have available.
  2. You can set/change the synclient options using this command: syclient var=1 (where var is the variable you wish to change and 1 the value)
    Read the manual page about each variable: http://manpages.ubuntu.com/synaptics
What worked for me
Instead of figuring out how to press both buttons of the touchpad, keep/press two fingers on the touchpad and click on the left click button of the touchpad with a third finger. This emulates a middle button by default.
What worked for the original poster
a) Setting the TapButton variable works for the two fingered tap
b) If you still want to click both buttons and produce a middle button emulation, execute:
synclient EmulateMidButtonTime=100
EmulateMidButtonTime allows you to change the time required to produce a middle button (allowed time period to click both buttons). 100 means 100 milliseconds (ms).
You may set it to even higher values, such as synclient EmulateMidButtonTime=500 (500ms).
16
With Ubuntu 17 f. and in XFCE the middle mouse button copy paste did not work at all.
Same solution still in Ubuntu 22.x. applicable ;-)
Solution for X (Wayland see bottom)
(middle mouse button & scrolling for my Logitech Trackball Marble Mouse)
To enable the middle mouse button paste function edit the xinput.
  1. Query your device:
     xinput list
Identify your mouse. With me it was device number 10.
  1. xinput list-props 10 gives me the settings for the mouse.
  2. I need to change the value for "libinput Middle Emulation Enabled (294):" and I need to do it as root:
     xinput set-prop 10 "libinput Middle Emulation Enabled" 1
  3. Check if the value changed to 1:
Yes, it works: "libinput Middle Emulation Enabled (294): 1"
In a recent Ubuntu 20.x connecting a Logitech Marble Mouse with 2 buttons (old, white model) gave me "libinput Middle Emulation Enabled (292): 0" and I changed it accordingly.
In Ubuntu 18 and XFCE there is a significant change: NO LONGER "libinput Button Middle". Instead "Evdev Third Button Emulation". So the whole line is now (for my machine):
sudo xinput set-prop 10 "Evdev Third Button Emulation" 1
To make it persistent, add a line in ~/.xstartup!
In my case it just looks the same like before:
That makes it effective from start on.
HINT: If yor flavour or surface of Linux GUI does not support xinput you might get a little error line each time you open a terminal.
Better solutions are always welcome :-)
This is what is behind it.
I strongly disagree that Ubuntu and Gnome decided to disable the standard Unix Middle Mouse paste. Even in XFCE Ubuntu 17 it is devastated. May the managers behind this decision find a soon and painful end. You make my life hard.
Many, many thanks to Gilles who found the solution!!!
I had the same issues using Ubuntu 16, 14.10 and earlier: Unix style copy paste in the terminal not working. Disappointing default settings. However, here is a solution (partly a wrap up of other peoples great work):
  • To fix the terminal issue I successfully put the following lines into my xorg.conf:
(see if /etc/X11/xorg.conf is suitable for you. May be different for Lubuntu etc.)
Section "InputClass"
    Identifier "middle button emulation class"
    MatchIsPointer "on"
    Option "Emulate3Buttons" "on"
EndSection
  • The very anoying malfunction of a missing 3rd mouse button (touch pad, Marble Mouse) can actually be fixed with the "gpointing-device-settings". Just install using CLI with:
    apt-get install gpointing-device-settings
Then invoke gpointing-device-settings to get the gui window. Remark: There is an unfixed bug in newer Ubuntus that wipes out your settings when rebooting. You may put gpointing-device-settings in auto-start but still need to prompt then. I am not aware of any proper config solution.
Probably some steps need a sudo or root access. I assume you know.
However, now I can use the unixish copy paste by mark and middle mouse button. At least in terminal. And for the Marble Mouse there is a separate article with a lot of config details.
Addendum
With Ubuntu 17 and in XFCE the middle mouse button copy paste did not work at all.
Wayland is different.
Sometimes it is helpful to enter
With some luck it is persistent. Else try to create a start script.
addendum Wayland update 2024
with gsettings list-schemas | grep periph you may find something like org.gnome.desktop.peripherals.trackball
Exciting! (unfortunately it is still gnome)
gsettings list-keys   org.gnome.desktop.peripherals.trackball
may show middle-click-emulation
here with luck it might help:
gsettings set  org.gnome.desktop.peripherals.trackball middle-click-emulation  true
If you are lucky owner of a 4 button logi Trackball you might want to scroll with the little button. If even more luck is on your side you may achieve scrolling this way:
gsettings set  org.gnome.desktop.peripherals.trackball  scroll-wheel-emulation-button 9
((8=little left, 9 little right))
This is working successful for my Logitech Trackball Marble Mouse manufactured by Suzhou Logitech Electronics Co., Ltd. China under Wayland on Ubuntu 20.04.6 LTS
opinion_no9
  • 1,072
You can also set the middle mouse button on a triple-finger-tap by calling
synclient TapButton3=2
(Put this in a script and add it to your startup programs)
It is strange, cause there seems to have been a bugreport, that supposed to have been fixed.
source: enable a three finger tap on my synaptic touchpad:
rubo77
  • 34,024
  • 52
  • 172
  • 299
Enable it for all users by changing the default value in /usr/share/glib-2.0/schemas/org.gnome.settings-daemon.peripherals.gschema.xml:
Look for the key middle-button-emulation that looks like this:
<key type="b" name="middle-button-enabled">
  <default>false</default>
  <summary>Middle button emulation</summary>
  <description>Enables middle mouse button emulation through simultaneous left and right button click.</description>
</key>
Change default to true:
  <default>true</default>
</key>
d_inevitable
  • 1,922
I found a nice solution using xubuntu 14.10
(I think this is nice because it doesn't require tap to click to be enabled, I don't like tap to click)
First you need to install xdotool
sudo apt-get install xdotool
Then write a bash script to send the middle mouse click. Your going to want to write something like this
#!/bin/bash
xdotool mousedown 2;
xdotool mouseup 2;
Save it to a filename you'll remember like "MiddleClick.sh"
next change your permissions to the file to make it executable for yourself
chmod u+x MiddleClick.sh
You can now send a middle click to where ever your mouse is by running this file, in terminal it would be
bash MiddleClick.sh
However, to assign a shortcut to do this, go to Settings > Keyboard and go into the Application shortcuts. Add a new one, point to the file you created and assign a shortcut. you can now use this new shortcut to send a middle click.
Tom B
  • 121
I have stolen some area from the right and left buttons on the touchpad using synclient, so that I can have all 3 buttons at the bottom of touchpad:
synclient MiddleButtonAreaTop=4035
synclient RightButtonAreaLeft=3890
synclient MiddleButtonAreaRight=3890
synclient MiddleButtonAreaLeft=3155
I computed the values using the current edges as base:
LeftEdge = 1685
RightEdge = 5361
TopEdge = 1489
BottomEdge = 4409
RightButtonAreaTop = 4035
Adding to @rubo77's answer and based on the output of your synclient you should try:
synclient ClickFinger3=2
Then you can use a 3 finger tap to activate the middle button click. It worked for me.
