18
Yesterday, suddenly my touchpad on my MSI Laptop started to not respond. In other words, in Login screen, touchpad is working as expected. However, in Desktop screen, after I have logged in, touchpad is not working.
How can I enable touchpad in Desktop?
lgarzo
  • 20,492
9 Answers9
25
I accidentally disabled my touchpad. This is the way I found to re-enable it.
Press the "Windows key" to open the start menu. Type "terminal" and enter, to open the command line.
Then type:
xinput list
Find the 'id' of your touchpad. For me it looks like this:
Virtual core pointer                        id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ TPPS/2 IBM TrackPoint                     id=12   [slave  pointer  (2)]
⎜   ↳ SynPS/2 Synaptics TouchPad                id=11   [slave  pointer  (2)]
My touchpad has id = 11.
Then type
xinput set-prop 11 "Device Enabled" 1
(but replace 11 with whatever id your touchpad had)
muru
  • 207,228
23
This work for me on kali linux:
gsettings reset org.gnome.desktop.peripherals.touchpad send-events
The schemas dir can be found by:
gsettings list-schemas
Edit: This works on Ubuntu 18.04 as well.
Diverso
  • 231
Running Ubuntu 16.04 there is a painfully simple way to re-enable the touchpad if you disabled it via the "Mouse & Touchpad GUI":
  • ALT+TAB to select the "Mouse & Touchpad GUI" if you currently do not have it focused. (Or use the Windows key -> Search for "Mouse and touchpad" -> ENTER)
  • Use TAB to iterate through the items within the GUI until the ON/OFF slider is highlighted.
  • Hit ENTER to toggle the switch back to "ON".
I realize this is very simple, but it took me an embarrassingly long time to figure out.
kelvinelove
  • 1,619
You could try the following command in a terminal and see if it helps, I always used it to restart the touchpad on 11.10 when it stopped working, but I have had no problems on 12.04.
synclient Touchpadoff=0
Make sure that the Touchpad is enabled. On an MSI laptop to Enable or disable the touchpad: FN+F3.
Mitch
  • 109,787
I don't recall having this problem in 12.04 either but running the gpointing-device-settings command and unchecking Disable touchpad always did it for me in 11.10.
Ikalou
  • 41
I'm using Linux Mint and disabled the touchpad, and like others before me, I noticed how hard it is to switch it back on if you don't have a mouse handy.
Using the Mint Preferences to disable the touchpad won't let you enable it again by using xinput or synclient as suggested in various places.
tl;dr
gsettings set org.cinnamon.settings-daemon.peripherals.touchpad touchpad-enabled true
Longer version on how I managed to get it back.
I dumped the cinnamon config to a file with:
'dconf dump /org/cinnamon/ > mysettings'
Under the heading 'settings-daemon/peripherals/touchpad' i found 'touchpad-enabled=false'
List the schemas and find something related to the touchpad
gsettings list-schemas | grep touchpad
List the keys in the touchpad-schema
gsettings list-keys org.cinnamon.settings-daemon.peripherals.touchpad
Enable the touchpad
Some useful links:
I have had the same problem but I found the fix for mine to be very simple. I unplugged my mouse out of the USB port on the laptop and the touchpad immediately started working again. It disables the touchpad when you have a mouse plugged in. My Laptop's model is the MSI Apache Pro-012 (GE70)
seagull
There is a little button at the bottom of your keyboard on the laptop (sometimes just above the touchpad) mine looks like a W but isn't Windows key, if you have that tiny button it enables and disables your touchpad.
Terry
