172
The same command is listed in my history again and again. How can I avoid this? I know it's possible via HISTCONTROL but I haven't found the right way.
Kazark
  • 698
karthick87
  • 84,513
6 Answers6
196
From the bash man page:
HISTCONTROL
A colon-separated list of values controlling how commands are saved on the history list. If the list of values includes ignorespace, lines which begin with a space character are not saved in the history list. A value of ignoredups causes lines matching the previous history entry to not be saved. A value of ignoreboth is shorthand for ignorespace and ignoredups. A value of erasedups causes all previous lines matching the current line to be removed from the history list before that line is saved. Any value not in the above list is ignored. If HISTCONTROL is unset, or does not include a valid value, all lines read by the shell parser are saved on the history list, subject to the value of HISTIGNORE. The second and subsequent lines of a multi-line compound command are not tested, and are added to the history regardless of the value of HISTCONTROL.
So put the following line in your ~/.bashrc:
export HISTCONTROL=ignoreboth:erasedups
Isaiah
  • 60,750
35
Stick this in your ~/.bashrc:
export HISTCONTROL=ignoredups
You could instead use ignoreboth. This it shorthand for both ignorespaces (commands starting with spaces) and ignoredups (duplicates).
I prefer ignoredups on its own as I find the default behaviour of ignoring commands with spaces at the front quite annoying when I copy a command off a website and it doesn't get saved because I accidentally copied in a space too.... But to each their own.
Oli
  • 299,380
18
Putting this in ~/.bashrc will apply @alvin's solution across different sessions as wlell
HISTCONTROL=ignoredups:erasedups
shopt -s histappend
PROMPT_COMMAND="history -n; history -w; history -c; history -r; $PROMPT_COMMAND"
Source: Linux: Bash history: “ignoredups” and “erasedups” setting conflict with common history across sessions
Nour Wolf
  • 281
Add the following to your ~/.bashrc:
To do this, you can use this command:
nano ~/.bashrc
jrg
  • 61,707
export HISTCONTROL=erasedups
To uniqely record every new command is tricky. First you need to add to ~/.profile or similar:
PROMPT_COMMAND='history -w'
Then you need to add to ~/.bash_logout:
history -a
history -w
Zombo
