The default .bashrc in the standard distribution of Ubuntu 16.04 that comes with AWS has these lines:
# don't put duplicate lines or lines starting with space in the history.
# See bash(1) for more options
HISTCONTROL=ignoreboth
However, it doesn't seem to work. I have been running pm2 restart myApp and pm2 list repeatedly using the Up Arrow key, and the command buffer now contains nearly a hundred lines of these.
What could be wrong?
u936293
  • 731
It's working as intended. ignoredups, implied by ignoreboth, doesn't add a command to history if it's the same as the immediate previous command. It doesn't look further back in history. From the manual:
A value of ‘ignoredups’ causes lines which match the previous history entry to not be saved.
So, this will add foo twice to the history:
$ foo
$ bar
$ foo
But so will this:
$ foo
$ bar
$ foo
$ foo
The last foo won't be added to history, since the previous command was foo. Use erasedups in conjunction:
A value of ‘erasedups’ causes all previous lines matching the current line to be removed from the history list before that line is saved.
So:
HISTCONTROL=ignoreboth:erasedups
CervEd
  • 172
Olorin
  • 533
