Is there a 'Startup applications' app for lubuntu?
Or how do I add apps to startup? I attempted a tutorial to add entries to ~/.config/autostart, but it did not work. Isn't there an easy way? Any ideas please?
There is a default application for this on the Lubuntu. Check it out:
- Press the Lubuntu icon on the bottom left;
- Select "Preferences" > "Default applications for LXSession";
- In the opened window, select the option "Autostart";
- Now you can enable or disable the autostarted applications, check/uncheck one in the listm or set manually on the field and pressing the "Add" button.
- 910
- 9
- 23
You can install the programm lxsession-edit from the software center. It will give you an interface like the "startup applications" app.
Or you can add programs by editing the file /etc/xdg/lxsession/LXDE/autostart. (In new Lubuntu is path /etc/xdg/lxsession/Lubuntu/autostart)
To do this press Alt+F2 and type gksu gedit.
Or the cleanest way (that didn't work for you) adding .desktop files to /home/username/.config/autostart and make sure they're marked as executables.
Here is a default syntax for a .desktop file with some of the most important entries.
[Desktop Entry]
Type=Application
Encoding=UTF-8
Name="NAME OF THE APPLICATION"
Comment="WHAT DOES THE APP DO?"
Exec="EXECUTABLE PATH OF APPLICATION"
Hidden=false
NoDisplay=false
Terminal=false
Example:
[Desktop Entry]
Type=Application
Encoding=UTF-8
Name=Firefox
Comment=Firefox Web Browser
Exec=firefox
Hidden=false
NoDisplay=false
Terminal=false
For applications that have their binaries in /usr/bin, you don't have to put the full path, just the name of the executable.
Save as YOUR_APPNAME.desktop in ~/.config/autostart/.
Log out and back in and it should have worked.
In Lubuntu 18.10 onwards (i.e. with LXQt):
- Lubuntu icon on bottom left (start button);
- Preferences;
- LXQt settings;
- Session Settings (or LXQt Configuration Centre, followed by Session Settings);
- In the window that opens, select "Autostart" on the left, then click "Add" on the right.
You can also remove items from the Autostart list by unchecking their boxes - as long as you know what you're removing.
- 71
This works for Lubuntu based on Ubuntu 18.10:
Preferences -> LXQt settings -> Session Settings -> Autostart
- 21
You should be able to add the .desktop file to the directory you listed: ~/.config/autostart
Did you log out and back in?
The easiest way I have found to do this is to:
- Open up PCmanFM and go to
/usr/share/applications. - Find the application you're looking for and copy it.
- Open up
~/.config/autostartin PCmanFM. - Paste in the application you copied.
- Logout
Once you log back in, it should be working. If it's not, it may be a question of the app, not the autostart process. Which app are you trying to autostart? Maybe we can help you better with more details.
- 77,855
- 683
- 6
- 12
