As you say, zsh is similar in many respects to bash. It has some features you won't find in bash, and it can be extended in powerful ways. Don't think of moving as a kind of revolution, but rather as a series of evolutionary steps that help you in your daily work. Here are some hints from my .zshrc. Although you say you prefer single pieces of advice, this post is a longish list. Still it is a good idea to go through the points one by one. Just add the interesting bits to your ~/.zshrc and reload with source ~/.zshrc. A final tip: learn the keystrokes of zsh's default ("Emacs") keyboard shortcuts: ^A ^E ^W Alt-F Alt-B Alt-P ^L ^R. You can replace Alt by two separate keystrokes: Alt-P is equivalent to ESC P.
This gives you more extensive tab completion.
autoload -U compinit
compinit
Tab completion from both ends.
setopt completeinword
Tab completion should be case-insensitive.
zstyle ':completion:*' matcher-list 'm:{a-zA-Z}={A-Za-z}'
Better completion for killall.
zstyle ':completion:*:killall:*' command 'ps -u $USER -o cmd'
Changes the definition of "word", e.g. with ^W.
autoload select-word-style
select-word-style shell
Colors for ls.
if [[ -x "`whence -p dircolors`" ]]; then
eval `dircolors`
alias ls='ls -F --color=auto'
else
alias ls='ls -F'
fi
Shortcuts for ls.
alias ll='ls -l'
alias la='ls -a'
One history for all open shells; store 10,000 entries. This makes this into a useful memory aid to find the commands you used last time for ./configure etc. Use Alt-P (find command that starts like this) and ^R (search in history) liberally.
HISTFILE=~/.zhistory
HISTSIZE=SAVEHIST=10000
setopt sharehistory
setopt extendedhistory
Enables all sorts of extended globbing, such as ls **/*.txt (find all text files), ls -d *(D) (show all files including those starting with "."). To find out more, go to man zshexpn, section "FILENAME GENERATION".
# superglobs
setopt extendedglob
unsetopt caseglob
This is useful to remember commands in your history without executing them.
setopt interactivecomments # pound sign in interactive prompt
Type ".." instead of "cd ..", "/usr/include" instead of "cd /usr/include".
setopt auto_cd
Nice prompt.
PS1='[%T] %n@%m:%~# '
Display CPU usage stats for commands taking more than 10 seconds
REPORTTIME=10
Some commands you use extensively in Ubuntu.
alias 'a=sudo aptitude'
alias 'ai=sudo aptitude install'
alias 'ar=sudo aptitude remove'
alias 'au=sudo aptitude update'
alias 'ag=sudo aptitude safe-upgrade'
alias 'as=apt-cache search'
alias 'aw=apt-cache show'
Lists packages sorted by their size - useful when deciding which packages are taking up you disk space.
function apt-list-packages {
dpkg-query -W --showformat='${Installed-Size} ${Package} ${Status}\n' | grep -v deinstall | sort -n | awk '{print $1" "$2}'
