I'm trying to install software by using apt-get and ubuntu software center UI, when I try the ubuntu software center it gets stuck saying installing and installs nothing and when I try the apt-get it gets stuck at the point "0% [Waiting for headers]"
I tried modifying sources.list file. I installed ubuntu this morning. Do you have any suggestions for me ?
Thanks in advance for your time.
edit : After a while, I get the error 502 bad gateway
Pumpkin
  • 125
In case you're still able to access internet, try opening up the Software Center. Select Edit and Software Sources. From there make sure that the "Download from" is set to "Main Server". If not, select it and type $ sudo apt-get update to the terminal. Outcome still the same?
