I have Ubuntu 17.04 and I'm trying to install gns3 by using these commands:
sudo add-apt-repository ppa:gns3/ppa
Output:
 PPA for GNS3 and Supporting Packages. Please see http://www.gns3.com for more details
 More info: https://launchpad.net/~gns3/+archive/ubuntu/ppa
Press [ENTER] to continue or ctrl-c to cancel adding it
gpg: keybox '/tmp/tmpji7mkxvk/pubring.gpg' created
Error: retrieving gpg key timed out.
Then:
sudo apt-get update
sudo apt-get install gns3-gui
Output:
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  linux-headers-4.10.0-37 linux-headers-4.10.0-37-generic
  linux-image-4.10.0-37-generic linux-image-extra-4.10.0-37-generic
  linux-signed-image-4.10.0-37-generic
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  augeas-lenses bridge-utils cpu-checker cpulimit dmeventd dns-root-data
  dnsmasq-base dynamips ebtables gns3-server ipxe-qemu libaio1 libaugeas0
  libboost-random1.62.0 libdevmapper-event1.02.1 libfdt1 libiscsi7
  liblvm2app2.2 liblvm2cmd2.02 libnetcf1 libqt5websockets5 librados2 librbd1
  libreadline5 libspice-server1 libvirt-bin libvirt-clients libvirt-daemon
  libvirt-daemon-system libvirt0 libvncserver1 libxen-4.8 libxenstore3.0
  libxml2-utils lvm2 msr-tools python3-pyqt5.qtsvg python3-pyqt5.qtwebsockets
  qemu-block-extra qemu-kvm qemu-system-arm qemu-system-common qemu-system-x86
  qemu-utils seabios sharutils ubridge vpcs x11vnc x11vnc-data xvfb
Suggested packages:
  augeas-doc gns3 augeas-tools numad radvd auditd systemtap nfs-common
  zfsutils pm-utils thin-provisioning-tools samba vde2 qemu-efi sgabios ovmf
  debootstrap sharutils-doc bsd-mailx | mailx
The following NEW packages will be installed:
  dnsmasq-base dynamips ebtables gns3-gui gns3-server ipxe-qemu libaio1
  libaugeas0 libboost-random1.62.0 libdevmapper-event1.02.1 libfdt1 libiscsi7
0 upgraded, 52 newly installed, 0 to remove and 0 not upgraded.
Need to get 384 kB/42.9 MB of archives.
After this operation, 170 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://us.archive.ubuntu.com/ubuntu zesty-updates/main amd64 libxenstore3.0 amd64 4.8.0-1ubuntu2.4 [19.8 kB]
Err:2 http://us.archive.ubuntu.com/ubuntu zesty/main amd64 libnetcf1 amd64 1:0.2.8-1ubuntu2
  502  Bad Gateway [IP: ...]
Get:3 http://us.archive.ubuntu.com/ubuntu zesty-updates/main amd64 qemu-block-extra amd64 1:2.8+dfsg-3ubuntu2.7 [38.1 kB]
Err:4 http://us.archive.ubuntu.com/ubuntu zesty/universe amd64 python3-pyqt5.qtwebsockets amd64 5.7+dfsg-5
Get:5 http://us.archive.ubuntu.com/ubuntu zesty-updates/main amd64 qemu-kvm amd64 1:2.8+dfsg-3ubuntu2.7 [13.2 kB]
Err:6 http://us.archive.ubuntu.com/ubuntu zesty/main amd64 libvncserver1 amd64 0.9.11+dfsg-1
Get:7 http://us.archive.ubuntu.com/ubuntu zesty/main amd64 cpu-checker amd64 0.7-0ubuntu7 [6,862 B]
Ign:8 http://us.archive.ubuntu.com/ubuntu zesty/main amd64 dns-root-data all 2015052300+h+1
Get:9 http://us.archive.ubuntu.com/ubuntu zesty/main amd64 libreadline5 amd64 5.2+dfsg-3build1 [99.5 kB]
Err:8 http://us.archive.ubuntu.com/ubuntu zesty/main i386 dns-root-data all 2015052300+h+1
Fetched 177 kB in 1min 10s (2,525 B/s)
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/main/n/netcf/libnetcf1_0.2.8-1ubuntu2_amd64.deb  502  Bad Gateway [IP: ...]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/universe/p/pyqt5/python3-pyqt5.qtwebsockets_5.7+dfsg-5_amd64.deb  502  Bad Gateway [IP: ...]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/main/libv/libvncserver/libvncserver1_0.9.11+dfsg-1_amd64.deb  502  Bad Gateway [IP: ...]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/main/d/dns-root-data/dns-root-data_2015052300+h+1_all.deb  502  Bad Gateway [IP: ...]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Note that: I tried to install it several times by these commands.
The last line of above output says: run apt-get update or try with --fix-missing I updated and upgraded system several times,then i tried to install gns3 again,But it didn't work. And i don't know how to run --fix-missing.
Output of --fix-missing:
--fix-missing: command not found
These commands use Ubuntu-based distributions:
sudo apt-get update
When i couldn't install it that way,I decided to install it with these commands:
Debian-based distributions:
deb http://ppa.launchpad.net/gns3/ppa/ubuntu trusty main
deb-src http://ppa.launchpad.net/gns3/ppa/ubuntu trusty main
Then
Adding the following lines to your /etc/apt/sources.list:
Then running the following commands in terminal:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys F88F6D313016330404F710FC9A2FD067A2E3EF7B
sudo apt-get update
I couldn't install it again
Error: 502 bad gateway
After these,i typed gns3 in terminal,Output:
The program 'gns3' is currently not installed. You can install it by typing:
sudo apt install gns3
So i tried to install it with above command:
Output:
  dynamips libqt4-designer libqt4-help libqt4-scripttools libqt4-svg
  libqt4-test libqtassistantclient4 libxdo3 python-qt4 python-sip xdotool
Suggested packages:
  python-qt4-dbg
  dynamips gns3 libqt4-designer libqt4-help libqt4-scripttools libqt4-svg
0 upgraded, 12 newly installed, 0 to remove and 0 not upgraded.
Need to get 438 kB/10.2 MB of archives.
After this operation, 50.1 MB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu zesty/main amd64 libqt4-help amd64 4:4.8.7+dfsg-7ubuntu1 [207 kB]
Err:2 http://us.archive.ubuntu.com/ubuntu zesty/main amd64 libqt4-svg amd64 4:4.8.7+dfsg-7ubuntu1
Get:3 http://us.archive.ubuntu.com/ubuntu zesty/universe amd64 python-sip amd64 4.18.1+dfsg-1 [71.8 kB]
Err:4 http://us.archive.ubuntu.com/ubuntu zesty/universe amd64 libxdo3 amd64 1:3.20160805.1-3
Fetched 279 kB in 1min 4s (4,290 B/s)
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/main/q/qt4-x11/libqt4-svg_4.8.7+dfsg-7ubuntu1_amd64.deb  502  Bad Gateway [IP: 91.189.91.23 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/universe/x/xdotool/libxdo3_3.20160805.1-3_amd64.deb  502  Bad Gateway    Reading package lists... Done
Suggested packages:
  python-qt4-dbg
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/main/q/qt4-x11/libqt4-svg_4.8.7+dfsg-7ubuntu1_amd64.deb  502  Bad Gateway [IP: ...]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/universe/x/xdotool/libxdo3_3.20160805.1-3_amd64.deb  502  Bad Gateway [IP: ...]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? [IP:...]
Now,What should i do?
Sss
  • 1,032
I managed to install it...
I needed to change the server from Software Center, from US to the best server in my area
Then:
sudo apt-get update
Not this one:
Zanna
  • 72,312
Sss
  • 1,032
