$ sudo apt-get install cinnamon cinnamon-session cinnamon-settings
Reading package lists... Done
Building dependency tree
Note, selecting 'cinnamon' instead of 'cinnamon-session'
Note, selecting 'cinnamon' instead of 'cinnamon-settings'
The following information may help resolve the situation:
 cinnamon : Depends: gir1.2-muffin-3.0 but it is not going to be installed
            Depends: libcogl5 (>= 1.7.4) but it is not installable
            Depends: libmuffin0 (>= 1.0.0-0ubuntu1~precise) but it is not going to be installed
            Recommends: gnome-themes-standard but it is not going to be installed
            Recommends: gnome-session-fallback but it is not going to be installed
I added this PPA:
sudo add-apt-repository ppa:merlwiz79/cinnamon-ppa
Then ran the following command:
sudo apt-get update && sudo apt-get install cinnamon cinnamon-session cinnamon-settings
How can I install the latest Cinnamon desktop? How can I fix this error?
jrg
  • 61,707
jaorizabal
  • 3,778
This PPA does not contain the latest version of Cinnamon. It is relatively old given the rapid pace of development and the maintainer has not (as yet) updated this PPA.
As such, I would recommend you purge the PPA and install the latest version as per this Q&A:
how to
Install ppa-purge
sudo apt-get install ppa-purge
The purge the ppa:
sudo apt-get -f install
sudo ppa-purge ppa:ppa:merlwiz79/cinnamon-ppa
sudo apt-get update
fossfreedom
  • 174,526
This is an odd problem. Usually, apt-get automatically installs all of the necessary dependencies for a package. You should run sudo apt-get install cinnamon cinnamon-settings cinnamon-theme libmuffin0 gir1.2-muffin-3.0 libcogl5 to install Cinnamon.
Aaron Hill
  • 5,035
This is a package dependency problem.
Type these in the terminal:
sudo apt-get install gir1.2-muffin-3.0 libcogl5 libmuffin0
and reboot and then install Cinnamon.
If you still can't install Cinnamon,I recommend installing GNOME 3. This may not help, but after I installed GNOME 3 Cinnamon worked.(I also had the same problem.)
sudo add-apt-repository ppa:gnome3-team/gnome3
sudo apt-get update
sudo apt-get install gnome-shell
Then install Cinnamon again.
