My machine is Dell Precision 3480 with Intel AX211 WiFi adapter that Ubuntu cannot recognize. I have been following instructions from closely similar situations I found but still no luck. What I have done so far is:
- Fresh install Ubuntu 24.04 (manual install of iwlwifi suggested from similar issues)
- Fresh install Ubuntu 20.04 (applied some fixes from similar issues)
- Fresh install Ubuntu 20.04 then upgrade to 24.04
- Install all suggested backport iwlwifi firmware
- Configure BIOS, turned off secure boot, etc...
I did also have similar dmesg logs from this discusion: No hope for AX211 wifi working on ubuntu 20.04?
My kernel version by the way is 6.8.0-60-generic.
Edit:
Result of some commands clearly shows the WiFi adapter
command
lspci -nnk|grep -iA3 net; dkms status; mokutil --sb; sudo dmesg|grep iwl
output
00:14.3 Network controller [0280]: Intel Corporation Raptor Lake PCH CNVi WiFi [8086:51f1] (rev 01)
Subsystem: Intel Corporation Wi-Fi 6E AX211 160MHz [8086:4090]
Kernel modules: iwlwifi
00:15.0 Serial bus controller [0c80]: Intel Corporation Alder Lake PCH Serial IO I2C Controller #0 [8086:51e8] (rev 01)
00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (23) I219-LM [8086:0dc5] (rev 01)
Subsystem: Dell Ethernet Connection (23) I219-LM [1028:0c02]
Kernel driver in use: e1000e
Kernel modules: e1000e
01:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller PM9B1 (DRAM-less) [144d:a80b] (rev 02)
SecureBoot disabled
[ 4.873365] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 5.036015] iwlwifi 0000:00:14.3: CSR_RESET = 0x11
[ 5.036022] iwlwifi 0000:00:14.3: Host monitor block 0x0 vector 0x0
[ 5.036112] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 5.036147] iwlwifi 0000:00:14.3: value [iter 1]: 0x00000000
[ 5.036150] iwlwifi 0000:00:14.3: value [iter 2]: 0x00000000
[ 5.036198] iwlwifi 0000:00:14.3: value [iter 3]: 0x00000000
[ 5.036204] iwlwifi 0000:00:14.3: value [iter 4]: 0x00000000
[ 5.036209] iwlwifi 0000:00:14.3: value [iter 5]: 0x00000000
[ 5.036253] iwlwifi 0000:00:14.3: value [iter 6]: 0x00000000
[ 5.036256] iwlwifi 0000:00:14.3: value [iter 7]: 0x00000000
[ 5.036259] iwlwifi 0000:00:14.3: value [iter 8]: 0x00000000
[ 5.036261] iwlwifi 0000:00:14.3: value [iter 9]: 0x00000000
[ 5.036313] iwlwifi 0000:00:14.3: value [iter 10]: 0x00000000
[ 5.036357] iwlwifi 0000:00:14.3: value [iter 11]: 0x00000000
[ 5.036362] iwlwifi 0000:00:14.3: value [iter 12]: 0x00000000
[ 5.036365] iwlwifi 0000:00:14.3: value [iter 13]: 0x00000000
[ 5.036411] iwlwifi 0000:00:14.3: value [iter 14]: 0x00000000
[ 5.036413] iwlwifi 0000:00:14.3: Host monitor block 0x0 vector 0x1
[ 5.036419] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 5.036463] iwlwifi 0000:00:14.3: value [iter 1]: 0x00000000
[ 5.036466] iwlwifi 0000:00:14.3: value [iter 2]: 0x00000000
[ 5.036469] iwlwifi 0000:00:14.3: value [iter 3]: 0x00000000
[ 5.036471] iwlwifi 0000:00:14.3: value [iter 4]: 0x00000000
[ 5.036512] iwlwifi 0000:00:14.3: value [iter 5]: 0x00000000
[ 5.036516] iwlwifi 0000:00:14.3: value [iter 6]: 0x00000000
[ 5.036518] iwlwifi 0000:00:14.3: value [iter 7]: 0x00000000
[ 5.036521] iwlwifi 0000:00:14.3: value [iter 8]: 0x00000000
[ 5.036523] iwlwifi 0000:00:14.3: value [iter 9]: 0x00000000
[ 5.036566] iwlwifi 0000:00:14.3: value [iter 10]: 0x00000000
[ 5.036569] iwlwifi 0000:00:14.3: value [iter 11]: 0x00000000
[ 5.036571] iwlwifi 0000:00:14.3: value [iter 12]: 0x00000000
[ 5.036574] iwlwifi 0000:00:14.3: value [iter 13]: 0x00000000
[ 5.036577] iwlwifi 0000:00:14.3: value [iter 14]: 0x00000000
[ 5.036579] iwlwifi 0000:00:14.3: Host monitor block 0x0 vector 0x6
[ 5.036623] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 5.036626] iwlwifi 0000:00:14.3: value [iter 1]: 0x00000000
[ 5.036629] iwlwifi 0000:00:14.3: value [iter 2]: 0x00000000
[ 5.036631] iwlwifi 0000:00:14.3: value [iter 3]: 0x00000000
[ 5.036677] iwlwifi 0000:00:14.3: value [iter 4]: 0x00000000
[ 5.036680] iwlwifi 0000:00:14.3: value [iter 5]: 0x00000000
[ 5.036683] iwlwifi 0000:00:14.3: value [iter 6]: 0x00000000
[ 5.036685] iwlwifi 0000:00:14.3: value [iter 7]: 0x00000000
[ 5.036754] iwlwifi 0000:00:14.3: value [iter 8]: 0x00000000
[ 5.036834] iwlwifi 0000:00:14.3: value [iter 9]: 0x00000000
[ 5.036840] iwlwifi 0000:00:14.3: value [iter 10]: 0x00000000
[ 5.036842] iwlwifi 0000:00:14.3: value [iter 11]: 0x00000000
[ 5.036886] iwlwifi 0000:00:14.3: value [iter 12]: 0x00000000
[ 5.036891] iwlwifi 0000:00:14.3: value [iter 13]: 0x00000000
[ 5.036894] iwlwifi 0000:00:14.3: value [iter 14]: 0x00000000
[ 5.036896] iwlwifi 0000:00:14.3: Host monitor block 0x22 vector 0x0
[ 5.036942] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 5.037011] iwlwifi: probe of 0000:00:14.3 failed with error -110
