FIXED (I missed options word below). Popping sounds heard when starting audio files; setting power_save=0 works but only until reboot
Similar to: How to stop speaker random popping noise on Ubuntu 22.04
This workaround works but only until the next reboot: https://discussion.fedoraproject.org/t/loud-popping-sound-on-headphones-when-playing-all-media/74731/4
$ echo 0 > /sys/module/snd_hda_intel/parameters/power_save
I.e. this has no effect: "You can make it permanent by adding this text to /etc/modprobe.d/audio_disable_powersave.conf"
EDIT, sound is now fixed permanently after my attempts, prompted by @vanadium :
I had missed the word options in these instructions:
This setting will last until you reboot. You can make it permanent by adding this text to /etc/modprobe.d/audio_disable_powersave.conf:
options snd_hda_intel power_save=0
After correctly adding that options text line, I restarted Ubuntu, and now there are no more sound pops on starting media files,
End EDIT.
Have tried following these:
Annoying click/popping sound on Ubuntu 20.04
https://ubuntuhandbook.org/index.php/2024/10/configure-audio-wireplumber-ubuntu-24-04/
https://support.system76.com/articles/serval-dac/
https://linuxconfig.org/how-to-install-pipewire-on-ubuntu-linux
but either they have no effect or yield errors.
The linuxconfig page fails for me at step 4:
$ systemctl --user daemon-reload
Failed to connect to bus: No medium found
My env:
SHELL=/bin/bash
COLORTERM=truecolor
SUDO_GID=1000
LANGUAGE=en_GB:en
LC_ADDRESS=en_GB.UTF-8
LC_NAME=en_GB.UTF-8
SUDO_COMMAND=/usr/bin/su
LC_MONETARY=en_GB.UTF-8
SUDO_USER=[anon]
PWD=/home/[anon]
LOGNAME=root
XAUTHORITY=/run/user/1000/gdm/Xauthority
HOME=/root
LANG=en_GB.UTF-8
LC_PAPER=en_GB.UTF-8
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=00:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.avif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:*~=00;90:*#=00;90:*.bak=00;90:*.crdownload=00;90:*.dpkg-dist=00;90:*.dpkg-new=00;90:*.dpkg-old=00;90:*.dpkg-tmp=00;90:*.old=00;90:*.orig=00;90:*.part=00;90:*.rej=00;90:*.rpmnew=00;90:*.rpmorig=00;90:*.rpmsave=00;90:*.swp=00;90:*.tmp=00;90:*.ucf-dist=00;90:*.ucf-new=00;90:*.ucf-old=00;90:
XDG_CURRENT_DESKTOP=ubuntu:GNOME
LESSCLOSE=/usr/bin/lesspipe %s %s
LC_IDENTIFICATION=en_GB.UTF-8
TERM=xterm-256color
LESSOPEN=| /usr/bin/lesspipe %s
USER=root
DISPLAY=:0
SHLVL=1
LC_TELEPHONE=en_GB.UTF-8
LC_MEASUREMENT=en_GB.UTF-8
LC_TIME=en_GB.UTF-8
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
SUDO_UID=1000
MAIL=/var/mail/root
LC_NUMERIC=en_GB.UTF-8
_=/usr/bin/env
System Details:
# System Details Report
Report details
- Date generated: 2025-05-14 12:57:00
Hardware Information:
- Hardware Model: LENOVO IdeaPad Z580
- Memory: 8.0 GiB
- Processor: Intel® Core™ i7-3520M × 4
- Graphics: Intel® HD Graphics 4000 (IVB GT2)
- Disk Capacity: 1.0 TB
Software Information:
- Firmware Version: 5FCN91WW
- OS Name: Ubuntu 24.04.2 LTS
- OS Build: (null)
- OS Type: 64-bit
- GNOME Version: 46
- Windowing System: X11
- Kernel Version: Linux 6.8.0-59-generic
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC269VC Analog [ALC269VC Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [BenQ GL2450H]
Subdevices: 1/1
sudo lspci -v gave, among other things:
00:1b.0 Audio device: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller (rev 04)
Subsystem: Lenovo 7 Series/C216 Chipset Family High Definition Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 29
Memory at f0710000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [130] Root Complex Link
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
