I'm using this script from HN* to select regions on the screen and copy their text, I took out the line with mogrify. It uses spectacle but it takes a moment before opening the UI, is it possible and would it be faster if Spectacle stayed open in the background? The slurp CLI starts instantly for me for selecting regions, I looked for command line screenshot tools to maybe use with it or has its own region support but didn't find any. Neither maim scrot and grim don't work on Plasma Wayland. I installed the ksnip flatpak but the option for rectangular regions doesn't show for me.
* The script:
#!/bin/bash
# Dependencies: tesseract-ocr imagemagick
# on gnome: gnome-screenshot
# on kde: spectacle
# on x11: xsel
# on wayland: wl-clipboard
die(){
notify-send "$1"
exit 1
cleanup(){
[[ -n $1 ]] && rm -r "$1"
SCR_IMG=$(mktemp -d) || die "failed to take screenshot"
shellcheck disable=SC2064
trap "cleanup '$SCR_IMG'" EXIT
#notify-send "Select the area of the text"
if which "spectacle" &> /dev/null
then
spectacle -n -b -r -o "$SCR_IMG/scr.png" || die "failed to take screenshot"
else
gnome-screenshot -a -f "$SCR_IMG/scr.png" || die "failed to take screenshot"
fi
increase image quality with option -q from default 75 to 100
mogrify -modulate 100,0 -resize 400% "$SCR_IMG/scr.png" || die "failed to convert image"
#should increase detection rate
tesseract "$SCR_IMG/scr.png" "$SCR_IMG/scr" &> /dev/null || die "failed to extract text"
if [ "$XDG_SESSION_TYPE" == "wayland" ]
then
wl-copy < "$SCR_IMG/scr.txt" || die "failed to copy text to clipboard"
else
# xsel -b -i < "$SCR_IMG/scr.txt" || die "failed to copy text to clipboard"
xclip -selection clipboard -i < "$SCR_IMG/scr.txt" || die "failed to copy text to clipboard"
fi
Notify the user what was copied but truncate the text to 100 characters
notify-send "Text extracted from image" "$(head -c 100 "$SCR_IMG/scr.txt")" || die "failed to send notification"
exit #!/bin/bash
on kde: spectacle
on x11: xsel
die(){
notify-send "$1"
exit 1
cleanup(){
then
else
fi
then
else
fi
exit
