The Camera app used to work with my USB webcam, but now it's either stuck waiting with Force Quit or Wait prompts, if I run it too early, or loads into a "Could not play camera stream" message with a black screen, while using Terminal to run ffplay /dev/video0 or vlc v4l2:///dev/video0 gets me a video just fine.
While cvlc v4l2:///dev/video0 gets:
VLC media player 3.0.20 Vetinari (revision 3.0.20-0-g6f0d0ab126b)
[00005d11a8026f60] dummy interface: using the dummy interface module...
[000078b908048bf0] xcb_window window error: X server failure
Is there a problem with this?
$ ls -l /dev/video*
crw-rw----+ 1 root video 81, 0 Mar 1 08:03 /dev/video0
crw-rw----+ 1 root video 81, 1 Mar 1 08:03 /dev/video1
The Camera app's debugging info:
Library Details:
Aperture 0.6.0
GStreamer 1.24.2
Pipewire 1.0.5
Gtk 4.14.2
Cameras:
GENERAL WEBCAM (V4L2) Video/Source: {
"object.path": (gchararray) "v4l2:/dev/video0",
"api.v4l2.cap.card": (gchararray) "GENERAL WEBCAM: GENERAL WEBCAM",
"device.id": (gchararray) "42",
"clock.quantum-limit": (gchararray) "8192",
"api.v4l2.path": (gchararray) "/dev/video0",
"device.devids": (gchararray) "20736",
"node.pause-on-idle": (gchararray) "false",
"node.driver": (gchararray) "true",
"device.product.id": (gchararray) "0x224",
"api.v4l2.cap.driver": (gchararray) "uvcvideo",
"api.v4l2.cap.capabilities": (gchararray) "84a00001",
"api.v4l2.cap.version": (gchararray) "6.8.12",
"device.api": (gchararray) "v4l2",
"api.v4l2.cap.device-caps": (gchararray) "04200001",
"device.vendor.id": (gchararray) "0x1b3",
"node.name": (gchararray) "v4l2_input.pci-0000_06_00.3-usb-0_4_1.0",
"node.nick": (gchararray) "GENERAL WEBCAM",
"priority.session": (gchararray) "1000",
"client.id": (gchararray) "35",
"object.id": (gchararray) "45",
"factory.name": (gchararray) "api.v4l2.source",
"api.v4l2.cap.bus_info": (gchararray) "usb-0000:06:00.3-4",
"media.class": (gchararray) "Video/Source",
"factory.id": (gchararray) "10",
"node.description": (gchararray) "GENERAL WEBCAM (V4L2)",
"object.serial": (gchararray) "45",
"media.role": (gchararray) "Camera",
