Things I tried and googled :Ubuntu 22.04 Reset System Bootloop
Already refer to this the problem is I do not have linux in my EFI list only microsot,HP,EFI? again, select microsoft will show up language and the bottom is mgmtrecovery.efi which you can press but pressing all this will stuck at loop boot system reset. Again I get suggested wrong suggestion and do wrong move. This is the whole list what did I do.
// IGNORE BELOW, THIS IS THE WRONG SUGGESTION I DO BY FOLLOWING THE VIDEO
What did I do:
Download Macrium reflect home trial clone all the C Drive to my brand new SSD.
2.Swap the SSD.
- Boot>however will show up GRUB COMMAND.
4.Troubleshooting using this video https://www.youtube.com/watch?v=Il73tKhZf7Y
My partition is (1,1) not (0,1)
Figure that everytime need to type in these commands everytime I restart/boot up my computer decides to remove this Linux.
Follow this video and remove Linux mentioning EFI https://www.youtube.com/watch?v=2zahv0g4j0Q
Updates windows 11 and restart
BOOT LOOP INTO SYSTEM RESET.MEANING POWER OFF COMPUTER AND PRESSING POWER BUTTON WILL SHOW BLACK SCREEN >SYSTEM RESET at top left corner really fast 1 sec turn off and restart itself.
TROUBLESHOOTING I TRIED.
1.TURN OFF SECURE BOOT> WHICH IF TURNING ON> WILL MAKE IT WORSE show an error security breach something.
2.Legacy Support ON and OFF. same results boot into system reset.
3.Check boot options> FANXIANG SSD 1TB MICROSOFT OS operating system Notes that: my HDD hard drive in D drive not showing up obviously as I can remember there is no OS in HDD.
4.Swap back to OLD SSD? No operating system found as I now found out that cloning C drive will entirely remove the old SSD content.(*I don't know cloning is "moving" not
The problem I think caused this:
Here is the step I did and I messed up the delete process by not obeying the "if it works don't touch it rules."Here is the video I exactly follow...
In EFI, there is these options
Microsoft
HP
Linux
after deleting Linux
there is only Microsoft and HP.
